Monitor heater model 41 keeps turning off during cold spells (AK)
Monitor heater keeps turning off every now and then, no certain times. It is not set for any times in general just on run
  • Nomi Thompson
    Nomi Thompson Jan 09, 2009
    I think that I solved the problem with an additive that was added. My monitor heater turned off when the temp went down to ( -30 below 0 ) I think that the oil was just thickening up. Otherwise it just clicked off. There was no amount of time before it quit, and I could see the flame. I will know if the heater is fixed by tonight. If it stay's running.
  • sstewart Jan 16, 2009
    I have a Monitor 41 that has recently been serviced. Can run for 3 days then shuts down. i put additive in outside fuel tank, but stll turned off 48 hours later. it is located in an office and goes off when no one is there. They come in to find Monitor off and freezing!!
There is a white cap on the back of the heater on the intake if you face
the heater and look down behind it it will be on the left take it off when it gets to be -20 it is a air intake and keep from iceing up in the intake pipe
Posted on Jan 13, 2010
    An expert whose answer gotĀ voted for 100 times.
  • 126 Answers
Can you give us more info? How long does it run before quitting? Have you ever been close when it quits? Do you hear a thumping noise when it quits. Can you see the flame?
Tom Hawkins
Posted on Jan 07, 2009
Unable to reset monitor to put time in, it just keep showing 88:88 flashing
There should be a button or slide switch to put the Monitor heater in the clock set mode. Once you get it in the clock set mode, use the up and down buttons to set the hour (up) and minutes (down). Let me know what model the heater is and I can tell you definitely how to set the time.
Nov 07, 2010 | Heating & Cooling
How many sq feet will a 41 model heat?
It all depends on how well your house is insulated. A Monitor 41 has the same output rating as a Monitor 2400. It should heat around 2000 sq. ft.
Feb 08, 2010 | Heating & Cooling
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
Problem with Screen in Horizontally Reduced
Set the screen resolution on the computer to some place like 1024x768. Use the menu buttons to resize the screen screen.
If the monitor is not keeping the settings it can be an indication to get a new monitor.
Aug 18, 2009 | Dell E773C 17" CRT Monitor
My monitor is displaying the contrast.... screen all the time!! I
Please check the display adjustments & cable connections of your monitor, if still the problem exists, then there's an internal electronic part/s of your monitor that are cold soldered / defective. I recommend to bring the unit to a service center to properly diagnose & fix the problem. best regards
May 22, 2009 | ViewSonic E70f 17" CRT Monitor
Continues to run
yes I would switch it over due to the fact that the balance point reached. Since I'm not there to look at the system monitor the actual temperature inside and if you cannot maintain the setpoint on the thermostat you may have to bring it back on. I've seen recently that there was not enough backup heat to keep the house warm enough during cold spells. Stay warm.
Dec 22, 2008 | Ruud Central System Air Conditioner
Monitor Heater 41
Our monitor heater was reading E-01. We decided that we would try cleaning the back of the unit and we landed up cleaning all parts of the unit that were visible. We plugged it back in and it works fine again. Thank you for your time.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
Heating & Cooling Logo
992 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
