Question about Sharp Personal Organizer & Spanish/English Translator
Some lines in LCD screen are falling out
In my SHARP electronic organizer LCD screen some hoizontal and vertical lines are falling out, or are very bleak. This is not problem of power, I check it. What can I do?
  • Kumham Jan 28, 2009
    I have a Sharp electronic dictionary. It has developed vertical lines in its LCD screen. I can not thus read the words well. Any solutions?
    My Sharp electronic English dictionary recently developed many vertical lines in its LCD screen. It made hard to read the letters. Any solutions?
    New Friend:
    Problem Solver:
  • 18 Answers
There is an easy fix if you have a soldering iron. When you take you organizer back cover off then you see the display connected to the circuit board via wide plastic strip which contains tiny metal lines. They run from the board to the display. From left to right, go back and forth with hot soldering iron on this wide plastic strip (on part which is on the circuit board) about 4-5 times. Not too fast not too slow. I managed to repair my display this way because hot iron revitalizes solder in the strip and connections will be cured. CAUTION: I went too careless with the soldering iron and I managed to burn in a little hole to the strip (on area which crosses air between board and display) so I have three vertical lines that don't work. Even this can be cured but is far more time consuming work.
Found similar information a while back from some post from the Internet. Don't know who originally posted it. Didn't manage to use this technique myself until now and I am glad it worked.
Thanks to the original poster somewhere.
Hopefully this information still helps someone.
Posted on Apr 21, 2013
    Problem Solver:
  • 6 Answers
Check the power voltage
Posted on Jan 13, 2009
How much will it take to fix a cracked membrane with vertical lines on it
Not worth fixing,if the LCD screen panel is damage or broken.Because LCD screen it limited produce it will cost the same as a new tv.Might even cost more after the LCD screen panel part and labors.The LCD screen panel is 90% of the tv,broken or damage LCD screen panel not worth as a whole tv anymore.The tv now only worth as salvage electronics boards parts.
Apr 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV screen doesn't light up for 20 minutes
sounds like caps in the powersupply are bad they take a long time to value up
Mar 01, 2010 | Sansui HDLCD-2600 26 in. LCD Television
Black horizontal line, red parallel vertical lines
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Personal Organizer & Spanish/English Translator Logo
625 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
