Question about Edirol UA-4FX External Sound System
Probs related to sound in pc
Sound is heard only sometimes when pc turned on.
when checked in audio n sound properties
- Voice options
-test hardware gives sound can't be played properly.
please help.
No sound driver in my laptop ibm t60
Posted on Jan 08, 2009
My chat mate cannot hear my voice , but i can hear her voice,, what should i do so that she can hear me?
Typical audio set up
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 11, 2010 | Yahoo Messenger
Mike problem
Hi ,
Please check in master volume control after going in control panel>sound options whether mic is not muted.
2.Again go to voice option in sounds properties there you will find the option for hardware testing and test the hardware .
In the last reinstall the drivers for sound
Aug 19, 2009 | Compaq Computers & Internet
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
Sound is heard only sometimes when comp turned on.
You have to download audio codecs for that matter. Go to this link:
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Jan 03, 2009 | Edirol UA-4FX External Sound System
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Audio CD sound Prob
Various conditions may cause this problem. To troubleshoot, check the following:Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
Joystick port is not working
The audio card joystick port conflicts with another joystick port in the system. Disable the audio card joystick port, and use the system’s joystick port.
The joystick drivers, MSJSTICK.DRV and VJOYD.VXD, may not be installed. Uninstall the joystick, then reinstall to load the drivers. The drivers should come with the driver CD or floppy diskette with your sound card.
Computer hangs or restarts during installation
A hardware conflict may cause the computer to hang or restart during the installation procedure. Check the following to resolve the conflict:
A hardware conflict with another device in your system.
Previously installed sound card hardware or software needs to be removed.
The audio card is not seated in the slot properly.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices.
Resolving hardware conflicts
Hardware conflicts occur when two or more devices contend for the same resources. Conflicts between your audio card and another device may occur regarding the I/O address, IRQ line, or DMA channel:
Right-click the My Computer icon on your desktop, and select Properties. The System Properties dialog appears.
Click the Device Manager tab. In the Device Manager, a plus sign(+) represents an expandable list of items. A minus sign (-) represents an expanded list. A circled exclamation mark denotes a conflict.
Double-click Sound, video, game controllers. A list of multimedia devices appears.
Select your audio card.
Choose the Propertis button.
Click the Resources tab.
Uncheck the Use automatic settings option.
Change "Settings based on:" if alternate settings are available.
Determine the conflict by reviewing the "Conflicting device list".
Select the conflicting item in the "Resource Settings" list.
Click the Change Settings button.
Use the mouse to select a new setting.
Select OK to close each of the properties windows, and restart your computer.
Audio card is not automatically detected
To manually configure your audio card for Windows 95/98:
Click "Start" on the taskbar, and select Settings from the Start menu.
Select Control Panel. The Control Panel group appears.
Double-click the Add New Hardware icon. The Add New Hardware Wizard dialog appears.
Select Next to continue.
Choose Yes to have Windows search for new hardware, then select Next
Select Finish, and follow the prompts to complete the new hardware installation.
CD does not automatically run when you insert it in the drive
To enable the "Audio insert notification" feature:
Click the Device Manager tab. A list of devices appears.
Double-click CD-ROM, and select your CD-ROM drive.
Choose the Properties button. The CD-ROM drive properties dialog appears.
Choose the Settings tab.
Click the "Auto insert notification" option to enable.
Select OK until all Properties dialogs are closed, and restart Windows for the changes to take effect.
No sound is heard from speakers
Verify the following:
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.
Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).
Ensure a hardware conflict does not exist between your audio card and another device in your system.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
If you are experiencing no sound only during audio CD playback, see "No sound is heard from audio (music) CDs" above.
Static sounds are heard in wave files
Check to see if the static sounds are heard in all wave files. If the difficulty occurs only with certain games, refer to the software manufacturer’s documentation. To troubleshoot static sounds heard in all wave files:
Try different resource settings for the audio card, or set the card to use low DMA.
Move the audio card to another PCI slot. Feedback from the power supply or another device may be responsible.
My sond card drivers is not available
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in
Aug 17, 2008 | Microsoft Windows XP Professional With...
Audio problem
problem like this cause of droping of your device, or pulling it away even your windows working.
now, seems your device experience problem as this, do this to check your audio:
click start>select control panel> select icons Sounds and Audio Devices>
On volume tab>there is device volume click the advanced tab below on it to check your volume control, leave boxes uncheck.
then, check your speaker settings click advanced>tab below it, then select your speaker set up.
then, now check your audio on sounds and audio devices properties click the Voice> tab then
Test hardware>.
Good luck. hope you can make it. and it help you both. thank you.
Jul 06, 2008 | Microsoft LifeCam VX-1000 Webcam
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Edirol UA-4FX External Sound System Logo
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
