Question about Sony Playstation 3 (PS3) Console
No picture comes through - the PS3 is working as i can hear audio
I connected my PS3 via HD, now there is no picture coming through but i can hear the audio and the games loading up.
On top of this the PS3 won't work with the scart cable now.
As i can't view anything i can't check the picture settings.
Can anyone help?
  • jonathan_der Jan 07, 2009
    I am not sure of progressive scan and cannot check without picture.
    Have tried connecting to another TV via scart but not working.
  • Michael Fisher
    Michael Fisher May 11, 2010
    Is It Set For Progressive Scan? Try Hooking It Up To Another Tv
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Connect PS3 to Sony Trinitron. We connected with the PS3 provided AV Cable to the front Audio/Video jacks but cannot get a picture on the TV screen. Not sure what we are doing wrong.
easy breezy fix, you have to force the ps3 to acknowledge that tv is not hdmi, it is just hd. press and hold power button for 5 seconds on ps3 until you hear 2nd beep and let go. settings will come up for ps3, switch to hd. done
May 22, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
