Question about Honda Pressure Washer PSI 3000
Wiring diagram for honda GX340
I need a wiring diagram for an old GX340 honda motor.
the last person played with it changed a few things.
I replaced the oil light switch ,so now it has spark ,but won't turn off.
It's around 1987 model,kew start. thanks
i found parts lists but not wiring (colours)
Dealers hasn't got old listing
  • jcsaws Jan 08, 2009
    found the problem fixed it. thanks
LandaNW
  • 45 Answers
SOURCE: I have a Honda GX340
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Posted on Mar 10, 2011
HondaAl
  • 72 Answers
SOURCE: oil around spark plugs on 1992 honda accord
Yes the oil can cause the car to lose spark, the oil leak could be caused by the valve cover gaskets around the spark openings, but 9 times out of 10 it is the spark plug tube "O" rings. The top of the valve train comes off of the head, the "O" rings are between the two halves, that will fix the oil leak.
Posted on Apr 22, 2009
SOURCE: 1992 HONDA ACCORD WILL CRANK BUT NOT START
No spark is uasually caused by a faulty coil or the trigger unit,both are inside the distributor. Get a used distributor fron a scrap yard (about $4o) and replace yours.Remove the dis.cap and turn the engine until the rotor is pointing to fire # 1 cyclinder,and mark the exact position of the base before removing from the block." Do not turn the engine" Install the other Dist. with the base in exactly the same position and the rotor pointing exactly to # 1 cyclinder. Note. Failing to install the other dist.exactly the way you took the first one out will throw the timing out!!!!!
Be doing all of this be sure there is no spark.
Naz
Posted on Apr 23, 2009
  • 174 Answers
SOURCE: Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Posted on Jun 16, 2009
lemmingleejn
  • 173 Answers
SOURCE: oil filter in civic 97
If you go to a reputable motor factor,
you can only be sold the correct filter for the civic.
As there are soo many variables in engine type, it's almost impossible to tell, oil volume, or which type filter.
However, I will say, be sure that you don't mix semi-synthetic oil, and mineral oil.
Oil changes should be undertaken every 30,000 miles, (unless under extra work load, (in which case, slightly more regularly))
Otherwise, 10/40 or 15/40 grade oil, is perfectly fine.
The trick to not overfilling the oil, is simply just to take your time, clean the dip stick and retry, until you have the correct reading.
Please don't forget to rate:)
Posted on Jul 29, 2009
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Why does Honda GX340 die immediately despite fresh gas, cleaned carb, and new plug?
Perhaps you haven't adjusted the carburetor correctly.The fuel supply orifice could be still plugged . Recheck the carb.
Aug 27, 2014 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Multiquip generator wont start
Multiquip GA-6HEB Honda motor will not make a complete revolution on the engine gets stopped goes back the other way and the same thing.
May 13, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
2005 Honda NF 100 Wave wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda NF 100 Wave wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
http://www.ethicalbox.co/honda_wave_100_service_manual_download.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Apr 13, 2014 | 2005 Honda NF 100 Wave
82 honda v45 magna ignition problems
Hi, Anonymous what you need is a wiring diagram that you can find in the back of your service manual if you can not find the first and best tool you ever bought for your bike, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1982 honda v45 magna wiring diagram Google Search
Honda 45 SABRE VF750S 1982 Shop Manual
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Apr 21, 2017 | 1982 Honda VF 750 S
Wipers dont work changed wiper motor fuse and still dont work
On a car over 15 years old the odds are the wiper motor failed
You need wiring diagrams to work on electrical
You have to see what is in the circuit you need resolved
No one can tell you how to diagnose things,you follow a
procedure that work for you
Don't change any parts
That is not how you work on a car
Learn how things work & test to confirm failure
Your not going to have relay failures as you read about
on these sites,too much bad info talked up on here
A fuse will blow if the motor or any motor fails,so that could be
a key do not replace a fuse,go to what it controls such a the motor
& try unpluging it & use the wiring diagrams to put power to it
Jan 31, 2013 | Honda Accord Cars & Trucks
How to replace valve timing gear in honda gx340 engine
Align crankshaft and balancer gear first. Rotate crankshaft and align timing gear. Alignment mark may be hard to see on crankshaft for timinig gear.
Jul 09, 2012 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Service manual honda gx340
HONDA GX340 GX340K1 ENGINE SERVICE REPAIR PDF MANUAL DOWNLOAD 1991-2001
HONDA GX340 GX340K1 ENGINE SERVICE REPAIR PDF MANUAL DOWNLOAD 1991 2001...
YOU CAN GET THAT REPAIR DONE TODAY!
EVERY SERVICE AND REPAIR JOB IS COVERED!
CLICK ON THE DOWNLOAD NOW BUTTON!
FACTORY TYPE PDF SERVICE REPAIR MANUAL!
With this Professional Quality, highly detailed Service Repair Workshop Manual you will be able to work on your vehicle with the absolute best resources available, which will save you a lot of money in repair costs and will also help you to look after your vehicle.
Contains step by step instruction & highly detailed exploded pictures & diagrams to show you how to complete the required job correctly & efficiently.
Covers the entire vehicle from front to back, its the same type of Manual that is used by Professional Mechanics to service or repair your vehicle.
** An absolute wealth on information at your fingertips!
** This manual is very easy to use!
** Print what you need when you need it!
** The ONLY Service Repair Workshop Manual You Will Ever Need!
** All repair procedures are covered!
** PC & MAC Compatible PDF
Instant Download means there is NO shipping costs or waiting for a CD or paper manual to arrive in the mail! You will receive this manual TODAY via Instant Download.
Nov 20, 2011 | Honda Electrical Supplies
Honda Pressure Washer PSI 3000 Logo
2,142 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
