Question about OKI Office Equipment & Supplies
Faint number of lines on the left hand side of my output for all colours
    Guru:
  • 859 Answers
The print head alignment to your platen is out of adjustment. This sort of issue is best left to a field tech. It involves adjusting a set screw on the left side of the platen pride profile. If you think you can find and adjust this set screw go for it. That's about all it comes to.
Sometimes there are other issues involved and not just this. So, that is why I recommend seeking out a field tech who has experience in typewriters and impact printers. If you can do this, I say again, go for it. Its not rocket science.
Best of luck in this.
Worldvet
Posted on Jan 07, 2009
  • 679 Answers
It occurs due to dust so clean the cartridge head and rod
  • rockfixya
    rockfixya Jan 07, 2009
    It sounds to me like clogged nozzles, if this is something that has been a recent problem. after doing your cleaning, are you running a nozzle check to see if you're missing any nozzles? Another this that may not be readily apparent is that by running the cleaning cycle, followed by a nozzle check, then if needed the next cleaning cycle, if needed, will be a stronger cycle, as long as you do the nozzle check in between cleaning cycles. You can do this 3 times in succession, each cycle being stronger than the last. If this fails, try a power cleaning, and/or the sscl cleaning, and try another nozzle check.
    Try not to turn off your printer if you don't need to, keep the printer level.
    Hope this is helpful--good luck.
  • 716 Answers
Can You Be More Specific?
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Faint Stripe down left hand side
Black Development roller faulty.parts cost $99.00 plus 99.00 labour with laserfast if in Australia.
Jun 07, 2009 | Samsung CLP 300 Laser Printer
Printing faint on left hand side of page
I had a similar problem, which I fixed by carefully wiping the drum with a soft tissue.
Jan 26, 2009 | Samsung CLX-2160N All-In-One Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
CANON PIXMA MP 460: PRINTING PHOTO- COLOUR PROBLEM.
change the print cartridge for color if yhat doesn't fix it get a new print head. Bob
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Vertical lines in my laptop screen
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit ctechnicians.com
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
14 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
