NSM Hit120 Jukebox
Thanks for your input. This machine doesn't have an opto sensor - it has a small magnet on the bottom end of the tone arm which activates a reed switch when it gets close to it at the end of a record play.
I have temporarily disabled the reed switch by cutting on of the two wires that are attached to it. No difference - it still rejects. Hope you can help.
Best Regards,
Skinnersunit (Australia)
  • 3 Answers
There's another switch inside/right near that encoded that clicks when the record is loaded. If loading/scrolling motor never stops during load unload i'd look there
Posted on Jan 09, 2009
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Apr 07, 2017 | The Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Hiya, I have a NSM The Performer wall. When I make a selection it goes to select disk but doesnt make a selection but gives error code 73. Having looked at the machine I've noticed at the back of the cd...
Hi Mark,
Go to the nsm website for the list of distributors and products etc, you should be able to order the parts from distribution.
www.nsmmusic.com
Regards
Alan Hood
ami-man
UK
Jul 18, 2009 | Wurlitzer Jukebox CD Player
NSM 2000 Jukebox Manual
You can usually find one on Ebay but don't search for NSM 2000 manual.
The operating technology is ES-V (or ES 5.1 depends how the seller lists it).
It covers all NSM jukes using the relevant technology rather than a specific model.
Jan 27, 2009 | Juniper Networks IDP Upgrade Kit for ISG...
NSM Hit120 Jukebox.
there is an opto sensor the gets blocked when the tone arm is at the end of the song. It looks like a black u mounted on a circuit board. The flag that interupts the sensor is on the tone arm. The opto must be dirty so it thinks it's at the end of the song and continues to the unload sequence dispite the tone arm having just started playing.
Jan 03, 2009 | Audio Players & Recorders
NSM Hit120 Jukebox circa 1970s. Fails to select and play.
Sounds like the encoder on the mech. It's the black gear on the lower right that rotates through the box with the wires soldered to it. (right next to the white gear that makes the whole unit go left to right.) It uses an optical sensor to count the holes in the wheel/gear. It's not registering either because of the wiring or more likely gunk inside the unit blocking the optical sensor.
Dec 11, 2008 | Audio Players & Recorders
No sound on 2710 Wurlitzer
Find the input to the amp from the tone arm. Play a record and while it is playing unplug the tone arm input. Stick a paperclip in the input of the amp...if it doesn't go HUMMMMMMMMM.....you have a dead amp....or the speakers arent plugged in.
Dave F.
Dec 08, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Problem with Auto Return on Thorens Turntable TD 147
Hi, contact me direct and I will send you the service manual. John. styluscity@gmail.com
May 05, 2008 | Thorens TD-190 Turntable
148 people viewed this question
 Grubhead
Grubhead
