Question about Electronics - Others
Bush combination DVD/Video problem
When we put any dvd disc in, a message comes on the television screen to say ''reading'' then ''incorrect disc''.
Please can you tell me what is wrong ?
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jan 14, 2009
My DVD player keeps saying "incorrect disc" when I
cd cleaner may help. lazers find it tough to read discs with dust on it.
Dec 30, 2010 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Toshiba TV/VCR/DVD combo (MW20F51) won't read/play dvds.
this a laser unit dirty or dead, needs to be cleaned with a laser cleaner kit or replace the laser unit
Feb 19, 2010 | Televison & Video
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Wrong disc on screen
If you DVD player is damaged, and u have external AUDIO\VIDEO inputs.Buy a $59.00 scan DVD player & save yourself a $100 repair bill.
The DVD heads coud be internittan { sometimes it works & sometimes i don't } U could have issues with the country codes that tell your DVD where the DVD CD was made at or where is was recorded.
Mar 26, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Incorrect disc message
Sounds as if the carriage has been trashed somehow. Incorrect loading of a disc of any sort can cause this sort of message...accordianman
Mar 16, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
DVD Video Player on Sansui Combo
I am having the same problem. But, some work and some don't. It is very frustrating.
Jan 11, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Bush Video Dvd combo Dvrhs02 Lock Code
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
Jan 03, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Dvd txa2028
could be that the tray is not fully loading it or the spinal is down more that it should or laser is bad, have to take it in for repair.
Dec 03, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Electronics - Others Logo
97 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
