Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
My slide in electric downdraft Jenn Air won't drain grease.
The grease from grilling doesn't reach the catch container.  It leaks out under the range.  I assume the lines are stopped up,
2 Suggested Answers
SOURCE: How do I get to the grease containers?
The grease container is at the bottom of the range. If you remove the front panel there is a little plastic cup that holds the grease. Hope this helps!!
Posted on Oct 26, 2008
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
Nov 26, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
I am wondering if with a Jenn Air downdraft electric range do I have to vent to the outside or does it recirculate? and is there a filter?
yes you have to or grease will build up under your house and I dont think there is a filter for this application but double check with a appliance supply house though I dont do alot of installs
Jan 10, 2009 | Kitchen Ranges
Grill Element
I believe this is working as designed! The downdraft fan always turns on when I run my own grill!
Oct 20, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Oct 10, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
42 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
