Question about O2 Samsung SGH-E250 Cellular Phone
Setting up emails
How do i set up emails xx
SMS tone
Posted on Jan 07, 2009
How to change ip address to konica minolta dialta 470 or connect to printer from computer
work out ip address of computer like for example usually 10.0.0.2 or 198.168.0.2 submask 255.255.255.0 then go to printer and select settings - network settings - ip address and put in xx.xx.xx.253
xx.xx.xx is the network address like 10.0.0 or 198.168.0 and the same subnet mask as computer is using. .
computer run
dos prompt
type in
ipconfig
press enter key
Jan 23, 2017 | Konica Minolta Office Equipment & Supplies
Closing email accounts
You'll have to de-activate your account,
so you will need to just click on the settings, and the click on the Deactivate option and just follow the steps
xx
Dec 10, 2013 | Computers & Internet
Brother MFC-9840CDW. I have just put in a new Drum, Belt unit & Waste Toner unit along with all new genuine toners. I have done all the resets for the Drum & Belt Units. Now it wont allow me to print...
Two things to try out.
Probably the easiest thing to do is to check the printer driver settings on your computer. Your printer driver has the option of printing in color or exclusively mono (black and white). Since your printer is printing, but only in mono or black mode, it seems like the printer driver would be the first place to start.
Secondly, it is possible through the web interface for the printer to specify that the output color is Auto, Color or B&W. It's possible you might have inadvertently changed this while you were resetting your machine after installing the replacement parts. (one can also do this through the Menu settings)
Go to the web interface by typing into your web browser
http://xx.xx.xx.xx, where xx.xx.xx.xx is the IP address of your printer. You may need to logon to the printer through the web interface. I believe the default password is access.
You should find an option for Printer Settings. Mine is in the right hand column near the top, Click on that link.
You might also try typing in the following link where xx.xx.xx.xx is the IP address of your printer. http://xx.xx.xx.xx/fax/printermain.html?id=outputcolor
The leftmost tab for the Printer Settings is Output Color. Make sure that Output Color is set to Auto rather than B&W. If it is set to B&W, you will not be able to print in color.
Hope this helps you out.
Oct 11, 2013 | Brother MFC-9840CDW Laser Printer
I just want to confirm that whether samsung s5333 supports push email or everytime we will have to download emails ourselves
Hello try the instructions below, if you do not have gmail or yahoo then you need to find the server info of your email provider or post the name of your email service provider so i can look up their info.
Gmail Account/Server Info
For Gmail, the configuration is
SMTP server: smtp.gmail.com
SMTP port: 587
Secure Connection: TLS
Incoming server type: IMAP4
IMAP4 Server: imap.gmail.com
IMAP4 Port: 993
Secure Connection: SSL
In your Gmail account, go to
Settings > Forwarding and POP/IMAP > IMAP Access > Enable IMAP
Yahoo Account/Server Info
For Yahoo,
Incoming (pop3)
pop.mail.yahoo.co.XX
Port: 995
Use SSL
Outgoing(SMTP)
smtp.mail.yahoo.co.XX
Use SSL
Port 465
Yahoo IMAP settings:
Server: imap-ssl.mail.yahoo.com
Port: 993
1. Delete the previously not working Gmail account in your phone
2. Press Menu
3. Select My Accounts
4. Choose the proper type of email account: Do NOT select "Google", but Exchange ActiveSync!
5. On the next screen fill out the Email address:
do not write yourusername@gmail.com, instead use yourusername@googlemail.com!
6. The username will be typed in automatically
7. Type in the password
8. Press Next
9. Press OK for the activation
10. On the next screen type in the server URL: m.google.com
11. Set Use SSL to ON (button turns green)
12. Press Set (left below)
13. On the next screen set the options you need: Email sync, Calendar sync, Contact sync, Task sync (below is another option in case of conflicts between data on the phone and the server)
14. There are further more options if you press the gear icon (sync: push/manual, push days/hours)
15. Press Done (left below)
16. Wait and see: voil?, push work like charm.
Apr 12, 2011 | Computers & Internet
I want to set up my new HP PHOTOSMART eSTATION C510 series Printer. Where I bought my printer said I would need a router. So I bought a new CISCO linksys E1000. When I got home and started to get...
. The printer's instruction guide should show you how to set the printer's IP address ?
it has to be in the range of what the modem / router you already have is.
If set to auto ip address on the printer
The existing modem / router would have a DCHP server most likely you could log into this router and look sat the ip leases and when it allocates a lease to the printer you set it as Static or permanent lease. There would be an ethernet port on the back of the router to plug in your printer to.
If manual setup then log into router / modem and set the dchp leases to start above 10 . it would be xx.xx.xx.1 to xx.xx.xx.254 just change it to xx.xx.xx.10 to xx.xx.xx.254 and xx means whatever it is set to for its network address. eg 10.0.0.1 - 10.0.0.254 . Set the printer to ip address to eg 10.0.0.9
On your MAC you may need to download and install a printer driver .
Mac is very clever and may set up the printer once you do this automatically by detecting the printer and setting it up in the MAC
If it is a wi fi printer you need to know the encryption settings by logging into the wi fi router and then set this up on the printer ?
May 13, 2017 | Computers & Internet
How to set up a Blueyonder.co.uk e-mail account on my new samsung wave phone
Step to setup an email account on Samsung wave:
1. Press Menu
2. Select My Accounts
3. Choose the type of email account you want to configure . For Gmail, select "Google "
4. Enter your e - mail address and password and click " Next "
5. A new window pops up. Select apply without making any changes.
You will need to configure your Gmail for IMAP or POP pushing first before authorization is given to your Wave to accept the pushed mail.
Login to Gmail -> Setting (top right hand corner) -> Forwarding and POP/IMAP -> Check Enable POP for all mail arriving from now on and check Enable IMAP.
You are done with configuring GMail side.
Now, add your google mail account under "My Account".
Enter your email (username will be filled up automatically), then your password.
Next, when you hit the next screen, DO NOT CONFIGURE ANYTHING. Simply "Set".
Make sure u have POP and SMTP enabled in your mail account before you try this and yahoo users make sure u enter your mail address as that of your domain
example : someone@yahoo..co.xx
where xx can be something like uk or us or in etc
Nov 01, 2010 | Samsung Cell Phones
I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
* type sudo dpkg -i *.deb
* Where is the linux source build directory that matches your running kernel?
* [/lib/modules/2.6.20-15-generic/build] press Enter
* Please enter region name for modem unit 0 [XXX] : type country name then press enter
* Please enter your email address [unknown] : type your email address then press enter
* Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
* Please enter license key [FREE] :
2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
3. get key: XX-XX-XX-XX-XX-XX
4. enter the key on Please enter license key [FREE] :
5. Copy hsfpatch to /usr/lib/hsfmodem :
* $ sudo cp hsfpatch /usr/lib/hsfmodem/
6. Execute patch file : $ sudo ./hsfpatch
* file 'modules/imported/hsfengine-i386.O' openend
* patching... done
7. Reconfigere hsfmodem : type sudo hsfconfig
* Press ENTER for all the questions
* Would you like to keep using them? [no]
* Please enter region name for modem unit 0 [XXX]:
* Please enter your email address [XXX@XXX.com]:Please enter
* license key [XX-XX-XX-XX-XX-XX]:
8. Reconfigure hsfmodem complete :
* Config for modem unit 0: /dev/ttySHSF0
* Device instance: 0-PCI-14f1:2f30-14f1:20d5
* HW revision : Basic2 2.18 Standard DAA 3VoltsIA
* HW profile name: hsfpcibasic2hsfi
* Registration ID: XXXX-XXXX-XXXX
* License owner : XXX@XXX.com
* License key : XX-XX-XX-XX-XX-XX
* License status : OK
* Current region : XXX (T.35 code: 0054)
* The /dev/modem alias (symlink) points to ttySHSF0
9. Install KPPP
10. Browse The World
Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Unread messages appear bold just for few minutes and then they turn as read. I recently set outlook to transfer emails from yahoo account and that might have changed something but do not know actually...
please check this field for the setting.
Tools -> Options -> Advanced -> General settings, do you have anything in the "Mark messages read after displaying for xx seconds"
Jun 08, 2009 | Yahoo Mail
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
O2 Samsung SGH-E250 Cellular Phone Logo
47 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
