Samsung 42h82 can anyone give me a overview of how to change the crt coolant on this tv it seems pretty common issue.......very fuzzy green and red i am pretty mechanical and i want to try doing this and where do i get the fluid is it universal?? name?? thanks
  • dcxguy48080 Jan 08, 2009
    i found a good site that shows how to do it..i will do it
    anyone that has any kind of mechanical sense can do it
    tv techs are not smarter than anyone else if given directions i am probably smarter than them lol
    thank you i will have the entire area covered with cloth and plastic not to get it anywhere i shouldnt......
  • 43 Answers
The fluid id called Glycal (spelling?) and it is like coolant, but unless you have the hose/pump to do it, I would let a TV shop handle it. It can be messy without those tools.
Posted on Jan 08, 2009
  • dhurt Jan 08, 2009
    I'm sure you can do it, it just can be messy. Make sure that once you fill the CRT that you move the CRT around and get all the air bubbles out. Also, don't do it on carpet. If it gets on the carpet it will not come out (oil based) Good Luck
I have a 63' projection TV. The picture is off. All of the lights are working, but the images are fuzzy, and you see the image tripled. The three images overlap each other in red, green, then blue. ...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2011 | Philips 55PP9363 55" Rear Projection...
Red tint around picture, images and such. seems like projector may be offset... with red... any ideas would be appreciative... Thanks.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 09, 2011 | Samsung HCM553W 55" Rear Projection...
The picture is a little blurry and the words a fuzzy
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 29, 2011 | Hitachi 50DX01B 50" Rear Projection...
We are seeing the top 3-4" on the TV turn fuzzy
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 57F500 57" Rear Projection...
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
I have a WD 65831 Mitsubishi television. I love it and have had NO problems so far with it. The picture and letters on the screen seem slightly fuzzy (out of focus). I had the bulb burn out and I replaced...
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
My 42H82 picture works but fuzzy...Letters in menu are clear though..need help
hi,
ur tvs crt sockets have some problem. change the three crt sockets at the same time . also check for screen voltages of crt's. increase it slightly. there will be three independent screen voltage adjustments for each gun.
ok
Dec 23, 2010 | Toshiba 42H82 42" Rear Projection...
My panasonic big screen screen has shadows and fuzzy picture
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Fuzzy picture
Oct 24, 2008 | Philips 55P8241 55" Rear Projection...
Blue crt shot
The coolant in the blue tube has no doubt congealed to an oatmeal like consistancy. Did you notice things like blue halos around things for some period of times. change the coolant. that should correct the blue. this is a common thing for that model as well as all TVs. Blue and green has this happen, Red seems to not have the same trait.
Mar 20, 2008 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
