Question about Refrigerators
I believe that the seal around the fisher & paykel freidge door is too old, how much for replacing with a new one? The phenominon is-- it always has water inside the freidge at out side of the freezer. Thank you very much
    Scholar:
  • 67 Answers
Heya,
Normally if the you think the seal is too old than it is, I normally work on commerical fridges and the way that I check is too shine a torch inside the fridge and see if you can see any light gaps.
Where abouts are you and I will recommend someone to be able to change the seals. Normally they are about60-110 Supply or 80-120 supply and Install.
I would highly recommend getting someone in to change it for you thou as If done wrong it can warp the fridge door
Hope that helps
Posted on Jan 07, 2009
Fisher and Paykel washing machine model WL80T65D leaking water on filling
were is the leak if leaking at door a new door seal check no clothing trapped in door if you run your finger over loose rubber part of seal at bottom and your finger goes through the seal is perished new door seal i am afraid
Dec 10, 2016 | Fisher and Paykel Washing Machines
My fisher and phosphate fridge is making a whining noise when door is closed?
sounds like the fan is either faulty or ice built up around fan, and the blade is hitting the ice - as the defrost heater may need replacing. Check for excess ice build up around door area (which would indicate the door not sealing correctly) or excess ice at rear could be due to faulty defrost heater, or the PCB board requires replacement.
Jul 23, 2016 | Fisher and Paykel Refrigerators
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Rubber has come off the door of my DW60CDX2 dishwasher
If the dishwasher is new and under warranty you could ask the Fisher and Paykel customer service to fix it.
Otherwise you need to work out which seal is involved, the one at the bottom of the door (attached to the door) or the one around the cabinet where the door fits.
Refer this site for parts and also the assembly diagram.Hope this helps.
Aug 17, 2012 | Fisher and Paykel Dishwashers
I need anew rubber seal around my oven door do i need a electrician or can i do it myself
This is a fairly straight forward job that most people can undertake. Carefully remove the old one and the new one is simply the reversal. If in doubt ask the supplier of the new seal his thoughts and a trick I use these days on all my new jobs is to take plenty of digital photos. you will be amazed how helpful they are are on reassembly. Cheers
Feb 09, 2011 | Fisher and Paykel OR24SDPWSX1 Stainless...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hello we have a fisher and paykel classic stove and top with four elements model no RA610MAW as we are in the bush we need to know how to change the seal in the oven which the door closes on we have the...
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Mar 19, 2010 | Fisher Ovens
F&P Intuitive WM. Needs Bearings and seals replaced
Hello you can get the parts from any New Zealand F & P service center( $50-80nz). You need a special F & P tool kit (you can buy for around $100nz from F & P also) to remove the seal and bearings and to insert the new. unless you know an appliance tech or have a service manual it could be a tricky one. cheers
Please Rate my Advice
thanks
Steve
Feb 22, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
