Question about Konica Minolta Magicolor 5450 Printer
Black smudge on side of paper when printing quanities
Black smudge goes from top to bottom of the page on one side only
I've found these smudges to be caused by a build up of toner on the edge of the drum. Carefull cleaning with a lint free cloth sometimes cures the problem.
This model also has a transfer belt, that could also be the cause of the problem.
Posted on Jan 08, 2009
    Champion:
  • 214 Answers
Hey, Pleas check Black imagine unit,if needed change it.
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
Black smudges at the top and bottom of printed photos
I had the same problem, until i went into the maintenence box, click on custom settings and check the prevent paper abrasion, this is designed for thicker paper and stopped it for a week or so, it did come back and so i took the printer back as it was only 4 weeks old.....
Aug 03, 2009 | Canon PIXMA iP1600 Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Konica Minolta Magicolor 5450 Printer Logo
646 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
