Question about Sharp 64LHP5000 64" Rear Projection Television
DTV mode states "Data base empty"
The television is a Sharpe HDD, the digital television has worked for since new (Jan 2006). The problem started on Mon 5th Jan 2009 with me not being able to access DTV. Can only get normal television channels.
    Problem Solver:
  • 4 Answers
If it is the power problem just check if ther fuse is intact if not make sure the rectify is in good shape if not chang it and also chang the power chip and transister enthen replase the fuse
Posted on Sep 11, 2010
I have a HP and I turn it on all lights come on the fan comes on it then blank screen set for the cursor Arrow which moves everywhere
no comptuer stated, of the 1000s made by hp from 1984 to now.
endless. list. and sub models. all very different.
what OS< ?? XP , vista, w7/8/10-??? what?
sounds like the windows login screen never gets attained right?
that means the OS is corrupted.
so if the machine has not been slammed.
and is 2006 or newer, power on and hammer the F11 key
called HP recovery.
not tell ing what PC you one or posted the full service tag data
well answers really are IMPOSSIBLE
like blind mechanic would be, reading the VIN in BRAIL.
impossible...
so the screen is not dead like most old CCFL PC become.
good.
so the BIOS key works, it tells you at power on to hit ESC to enter setup, (or what ever key it it) Getting BIOS working is, first.
in all cases. BIOS works (mostly) with HDD removed,
BIOS then can do F11 if the hDD is still good and connected.
Sep 15, 2017 | HP Computers & Internet
My 4980 won't tune any channels it keeps saying dtv data base empty, how do I fix this problem
firstly you need to set the input . I use an external antenna . input source is air then in menu I scan for channels and usually find about 20 in my area of the world .
Jul 01, 2016 | Televison & Video
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
Toshiba estudio 282 code F100
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Feb 25, 2013 | Toshiba e-STUDIO 282 Black and White...
Want to Know if my TV is a DTV
it most probably is DTV ready, try googeling some on the subject, but since its a LCD tv from 2006 its most likely to made with a digital tuner. Note : if you have cable or satelite ( dish networks, Direct Tv and so on ) you are allready watching digital TV and do not need a converter box.
Mar 05, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Feb 18, 2009 | Polaroid FLM-2632 Television
Error message - "data base is empty"
Hi John
I have the same problem, although my set is a 32". See my posting on AVForums.com (UK)
http://www.avforums.com/forums/freeview/984253-sharp-aquos-lc32d44e-losing-memory.html
My email address is pastel10@btinternet.com in case you want to contact me
Paul
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HDTV
If you mean does it have DTV tuning, the answer is no. (DTV is the new digital broadcasting which replaces the current analog system this coming February.) All TV's made after March 1, 2007 must have the digital tuning, but your set was made earlier than that. You would need to get a converter box if you aren't connected to cable or a satellite.
Dec 01, 2008 | Televison & Video
What steps to take after installing a hard drive on a toshiba 350
button.
Nov 26, 2008 | Toshiba e-Studio 350 Copier
Turns off by itself
Hi you can connect another additional totally empty HDD to your computer and boot thru one of the disk manager cd - its GUI based , under maintenance option it is possible to copy entire contents of existing HDD into the empty HDD you connected .If can see too much of dust accumulation then you consider the fan to be malfunctioning component else there exists a short circuit in other components.
Apr 14, 2008 | Mirra M-250 Server
Sharp 64LHP5000 64" Rear Projection Television Logo
70 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
