Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Prob with display
My monitor shows up nothing when the system is turned on...all the fans run and everything...i removed the ram and reinserted it but to no avail...is that something to do with motherboard....
  • glenn hoffman
    glenn hoffman May 11, 2010
    any error beeps-check bios make sure the correct vga is selected, onboard or add-on. hope this helps.
  • chinthaka Jayasinghe
    chinthaka Jayasinghe May 11, 2010
    i feel that you VGA has a issue, do you have a onboard VGA or a seperate VGA card?.
I got the same problem and i replaced my ram.now everything is fine. and once blow the dust with a blower.
Posted on Jan 20, 2009
    Problem Solver:
  • 4 Answers
JUst Format ur system and instal the driver for any querries just tell with operating system
ok
Thanq bye
Posted on Jan 09, 2009
  • 416 Answers
The model looks to be Asrock. which means the VGA is on board. i am sad to say your Motherboard might be busted. if you have warranty , go to the shop you bought it from.
    Scholar:
  • 172 Answers
The motherboard is most likely blown, is this pc an emachine or simlar pc world computer ?
The 865gv motherboard was extensively used in these pc's and failed with the same problem many times. I sell a superior board to repair this problem, which produces a complete and effective repair.
Contact me at compdoctor2005@btinternet.com
Posted on Jan 08, 2009
Hi I have Lenovo 3000 n200. When I try to turn it on I hear fan noise, DvD burner works, dark screen, nothing shows on screen and after that everything is silent. I did hard reset etc but no use. I...
On the back of the laptop there should be a compartment.Open it a find the RAM sticks.If you have 2 sticks,remove one and try to run it with only one and repeat the same process with the other stick.If you have an extra RAM please insert a it and run the laptop.
May 03, 2012 | Lenovo 3000 N200 PC Notebook
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Toshiba m100 my hand trying to have a power LED and battery LED fan works but I can not display the image signal.
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 03, 2011 | Toshiba Satellite M100 Notebook
My computer cant display anything but it normally comes on as usuall
after switching on everything check backside of your system (cabinet) - fan must be running normally - if it is running slowly or if it is not at all running then SMPS is deffective - IF FAN IS RUNNING NORMALLY THEN .....switch off everything - remove monitor's cable from system (cabinet ) & then switch on only monitor - then you will get ''no signal '' or some display or some colour on monitor - that means your monitor is ok & problem is with system - if you don't get anything then your monitor is deffective - IF MONITOR IS ALSO OK THEN.....switch off everything ....open cabinet's cover ...observe carefully ...on main board 1 cell (round shape)will be there - remove it & check its voltage using multimeter ...it should be atleast 2V & above ....maximum it will be around 3.2 V - if it is not ok then replace it ....IF CELL IS ALSO OK THEN ....remove RAM & re insert (in same slot or another slot)......then switch on .....if it works ok otherwise for testing purpose bring same type of RAM & fix it & check......if it works ok then RAM is deffective OTHERWISE ......there is a problem in main board................if you are using display card (graphics card ) then remove it & reinsert on another slot .....also observe on graphics card whether any capacitors are blown ......on main board also observe whether any capacitors are blown.....if possible for testing purpose bring 1 graphics card & check it ......technical person can do all these things easily ....for non technical person it is difficult............so if you can do ....try it otherwise call service engineer................iam babu - service engineer (computers, laptops, printers, etc..) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com ....
Apr 13, 2011 | Dell Dimension 2400 PC Desktop
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
P4I45GV R5 Motherboard: i have intel 945g motherboard the cpu fan runs but...
Check you Ram. If possible, try with another working ram. Clean the port. It is also possible that your cpu is overclocked, remove the bios battery and leave it outside for few minute and reinsert it and boot the system. If this doesn't helps, you'll need to check your display card also. Try the monitor on another pc. Still here to assist you further. good luck and thanks for using FixYa.
May 16, 2010 | Asrock P4I45GV R5 Motherboard
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Nothing appears on the monitor
This occurs mostly due to the the RAM which might not be plugged in properly.. remove the RAM, clean the base and plug it again.. mostly this causes this no display prob
Jun 16, 2008 | Asrock AM2NF3-VSTA (4711140874470)...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
