Question about Samsung RS2630SH Side by Side Refrigerator
RS2630SH REFRIGERATOR FAN IS MAKING NOISES
  • Anonymous Feb 26, 2009
    Fan is noise
  • 700 Answers
If its on thr\e inside then its hitting ice, thaw out the unit and then turn back on. easy way is to use a shop vac and thaw out the unit.
Posted on Jan 11, 2009
Fan making noise.
might be a sign of a defrost problem OR somebody may not have closed the door all the way. Unplug it and wait till tomorrow and plug it back in. If it starts making a noise right away I say fan motor if it makes noise after a couple weeks probably defrost problema.
SERVICE MANUAL
Feb 11, 2013 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs2630sh making noise and stops when the freezer door is opened
Sounds like you fan at the back. Mine is doing that at time for I've been having trouble with a drain valve plug and putting pressure on the whoe unit as well as the floor :(
Jan 20, 2013 | Samsung RS2630SH Side by Side Refrigerator
Noisy fan running constantly - fan noise caused by ice build up
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 27, 2011 | Samsung RS2630SH Side by Side Refrigerator
Coolong fan making a lot of noise
There are probably at least three fans in your refrigerator. I am assuming it is the fan in the refrigerator, check to be sure it is not being obstructed with ice or some other alien matter. If it is clear then you need to order a new fan ASAP. While you are at it check the condenser and condenser fan, they both probably need cleaning.
Good Luck,
Gilshultz
Nov 29, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fan noise
go to partstore order part #DA97-01949A and fix i had the same then late motor not work and the center very hot i fix my
Jun 22, 2009 | Samsung RS2630SH Side by Side Refrigerator
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Multiple Ongoing Problems w/ Samsung RS2630SH
noise from the back .. outside ? would be the fan motor DC ver-speed motors.. frosting over is likely a drain problem
Aug 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Skraching noise
I have the same problem with mine. I was told by a tech that it is probably the motor of the fan.... I'm researching online for that part.
Sep 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
633 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
