Question about HP OfficeJet G85 All-In-One InkJet Printer
Printer jams My paper jams after moving about 3 inches. I have pulled out the tray and tried to fix it but it continues to jam.
  • Evelyn Mann May 29, 2007
    Thank you so much. I pulled off the back of the printer and found a little part of a piece of paper caught in there. I am sure that is what was stopping my paper. Now unfortunately I have another problem. Every time I try to print something it says "error printing". I tried to troubleshoot and got the showpage to print so I know that the printer and computer are connected. In the control panel by my printer it says ready and the "offline" is not checked. I did notice the printer port is DOT4_001. It says that the LPT... port is the most common. I just can't figure this out. Thank you for your help
    Novelist:
    Champion:
  • 254 Answers
Have you checked the paper path for anything which might be lodged there? A small crumpled piece of paper, paper clip, or even some broken piece of plastic from inside the printer itself. Are the rubber rollers extremely dirty/covered with paper dust? Depending on the design of the printer, one set of rollers may be spring loaded, and if the spring is broken, disconnected etc, the tension on the roller of course goes away. Anything like this will prevent proper paper movement through the printer
Posted on May 29, 2007
  • Merwyn Bolles
    Merwyn Bolles May 29, 2007
    Check your cabling if you haven't already done so. Is this printer USB or parallel port connected? If parallel, double check that the connectors are properly seated at both the computer & printer.
    I assume you are using MS Windows?
    I've seen a problem similiar to what you are experiencing. An employee at the school where I work brought in an HP all in one, and his computer- I couldn't get the thing to print. Even tried subbing a different hard disk, & doing a fresh XP load, along with a fresh driver load. After a BIOS update on the computer, things suddenly began working, but I'm not really sure that was the problem. I had tried the printer on my Dell office machine, and the thing functioned fine. I tried a different printer on his computer- you guessed it, printing was fine. I wonder if the real problem is in HP's drivers, but I don't think I found anything on HP's site regarding such an ailment. Do a Google search "HP G85 no print" and see if you can find something.
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Paper jam
Have you tryed replacing replacing the pick up rollers? Also make sure that the paper guides are snug against the paper.
Jul 06, 2013 | Brother MFC-7820N Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Had paper jammed - removed jammed paper - but nerror light still on
    Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
    First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
    Paper is jammed inside the paper tray:
    1. Pull the paper tray out of the machine.
    1. Pull out the jammed paper to remove it.
    1. Reload the paper in the paper tray.
    2. Reinstall the paper tray.
    Paper is jammed inside the machine:
    1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
    1. Re-insert the jam clear cover.
    2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
    3. Remove the jammed paper.
    4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
    5. Gently move the print head to the center.
      Note Be careful to not force the print head to move.
      If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
    6. Examine under the print head. If anything is found, remove it.
      Note Use a flashlight if necessary to check thoroughly.
    7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
    8. Reconnect the power cord and telephone line.
    Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
    If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
    Thanks for using fixya......
    Oct 26, 2010 | Brother Office Equipment & Supplies
    I had a paper jam and I took the back off and this
    Step one: Remove any loose paper
    Remove all loose paper from the input and output trays.
    1. Turn off the product.
    2. Unplug the power cord from the back of the product.
    3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
    4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
    5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
    6. Carefully remove any jammed paper.
    7. Close the cover.
    8. Reinsert the rear-access panel or the duplexer into the product.
    9. Plug the power cord back into the product.
    10. Turn on the product.
    Step three: Open the top cover and clear the jam
    3. Open the carriage access door. The carriage moves to the right side of the product.
    4. Gently pull the paper out of the rollers.
    5. After clearing the jam, close the carriage door.
    6. Plug the power cord back into the product.
    7. Try printing a document.
    · If the issue is resolved, do not continue troubleshooting.
    · If the issue continues, proceed to the next step.
    Step four: Clear the jam from paper tray 1
    1. Remove all paper from the output tray.
    2. Turn off the product.
    3. Unplug the power cord from the back of the product.
    4. Lift the output tray and then check for jammed paper in input tray 1.
    Use these steps to remove any jammed paper.
    a. Raise the output tray.
    b. Grasp the jammed paper and pull it out of the product, toward you.
    c. Lower the output tray.
    5. Plug the power cord back into the product.
    6. Try printing a document.
    · If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
    · If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
    Step five: Clear the jam from paper tray 2
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    3. Remove the ADF input tray and open the ADF cover.
    4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
    5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    6. Check the ADF paper path for jammed paper.
    7. Check for jammed paper where paper enters the ADF paper cleanout.
    o If the paper comes out with gentle pulling, proceed to step 9.
    o If the paper does not come out with gentle pulling, follow these instructions.
    1. Open the ADF, and then use both hands to gently loosen the paper.
    2. When the paper is free, gently pull it out.
    3. Close the ADF.
    8. Lower the green lever.
    Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
    9. Replace the ADF input tray.
    10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
    o Make sure that the ADF frame is secure and attached correctly.
    o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
    o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
    1 - Stack stopper
    2 - Two-catch
    11. Plug the power cord back into the product.
    12. Turn on the product.
    13. Try printing a document.
    Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
    On tray 3, the bottom one, it trys to grab the papaer, then says paper jam. But theres no jam.
    The pickup rollers on your tray are worn out. If you pull out the tray and look at the pickup rollers they should have a rough surface and your are going to be smooth. The printer is trying to pickup the paper but can't so the printer thinks the paper is jammed. You will need to replace the rollers, a very easy thing to do. We sell the set of pickup rollers for $6.95 shipped.
    Contact us at 318-447-9040 or tech@ccl-la.com if you need a set.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    tech@ccl-la.com
    Dec 21, 2009 | Lexmark Optra T614 Laser Printer
    Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
    Answer:
    Fixing a printer paper jam
    When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
    1.Turn off the printer.
    2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
    3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
    4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
    5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
    * To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
    Preventing a printer paper jam
    As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
    •If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
    •Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
    •Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
    •Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
    •Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
    Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    HP 4200 printer paper jam. No paper is jammed
    OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
    As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
    Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
    The output would be the sensor in the fuser replace fuser.
    Hope this helps
    Feb 19, 2009 | HP LaserJet 4200 Printer
    Continuous paper jam when i try to print
    Hi ,
    Follow the steps below -
    1. check the media / paper compatibility. It sould be as per hp :
    Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
    Legal: 216 x 356 mm (8.5 x 14 inches)
    A4: 210 x 297 mm
    A5 148 x 210 mm
    Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
    A2: 111 x 146 mm (4.4 x 5.8 inches)
    DL: 110 x 220 mm (4.3 x 8.7 inches)
    C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
    A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
    127 x 178 mm (5 by 7 inches)
    Letter: 216 x279 mm (8.5 by 11 inches)
    A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
    A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
    US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
    ISO A5
    JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
    3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
    4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
    5. make sure you replace the cartridge if its refilled. It could provide obstruction.
    move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
    6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
    7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
    Apr 08, 2008 | HP Officejet 7210 All-In-One InkJet...
    HP OfficeJet G85 All-In-One InkJet Printer Logo
    65 people viewed this question
    Clive
    Clive
