Question about Canon NP 6551 Black and White Copier
Canon 6025 My copier NP6025 has been working fine, just resently all the copies are coming out very very dark. even when its on mannuel on the lightest setting. Can some one help. Thanks. Al
  • Alberto Ramirez May 30, 2007
    Great job it was the exposure.
    Thanks for your help. problem solved
    Al
  • 31 Answers
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is [email protected] Good Luck!!
Posted on May 29, 2007
E 001 press the power switch to off and then back to on
Posted on Nov 17, 2007
SOURCE:
GRAY STRIPES ON COPIES FROM CANON IMAGERUNNER 210S
Have you replaced the drum unit resently? When you had the drum unit out did you see the lines on the drum it self? If so, you need a new drum... If you did not see lines on it the problem may be coming from the fixing film, most of the time if the film is bad you can rub the toner off the page... Good Luck...
May 28, 2009 | Canon imageRUNNER 210S Copier
E711 code
...error code E711...mainboard malfunction...error in the mainboard...and see also the power supply mainboard...and check if the output voltage that came out from is working fine...to do this you must have a multitester to check the voltage...
May 13, 2009 | Canon Office Equipment & Supplies
Error message on canon np6025
LOL.... I just kept wiggling wires and connectors and all of the sudden it worked.... not real sure what I did .
Apr 09, 2009 | Canon Office Equipment & Supplies
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Canon NP6025 Service/Repair Help
yes I can go there for to see , but I need to now whats this machine have
Dec 12, 2008 | Canon NP 6551 Black and White Copier
Lost copy code on Canon NP 6025
It can be reset, but you may have to fix the problem first. And what is the problem with the copier, is it a 6025 or6551?
Jul 15, 2008 | Canon NP 6551 Black and White Copier
Canon np6025
I have a NP 6025 that is jamming from the letter tray top not multi purpose tray. I cleaned the rollers that did not help. its making a grinding noise (best way to describe it) The paper gets jammed at various stages in the input unit I can open the right door and see the paper. Wondering if anybody has any ideas on how to fix this problem....
Sean
Feb 16, 2008 | Canon NP 6551 Black and White Copier
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
381 people viewed this question
Clive
Clive
old marine
old marine
Ekse
