Question about Kodak EasyShare C330 Digital Camera
My camera wont turn on after download picture to PC
My camera will not turn on. Ichanged the batteries and I know they are in the right way. The last thing I did was download pictures from camera to laptop.
  • Michael Fisher
    Michael Fisher May 11, 2010
    When Did It Work Last?
  • 903 Answers
Http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=2/3/10&pq-locale=en_GB#
go here and click on the link that says my digital camera is broken, how can i get it repaired or serviced
and follow the step by step guide on fixing your problem
I hope this helps
Posted on Jan 10, 2009
Will not turn on
I assume you still can view and download the pictures from your camera to your computer.
When you have trouble charging the battery (ies) ready the following, because batteries get old and stop working. Sometimes they work for 10 years, but there are also batteries, that don't last one year.
Always be sure the battery is charged and suited for your camera. Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Jan 11, 2014 | Nikon Cameras
Wont turn on
My camera worked fine last night while I was taking pictures, however, I couldn't get it to power up today so that I could upload my pictures. I spent half the day recharging batteries, buying new batteries, and searching the Internet for solutions.
It turns out that I just needed to switch the batteries around. The positive and negative battery chambers are mislabeled in my camera. Duh! Works fine now.
Hope this helps someone.
Mar 30, 2009 | Kodak EasyShare C613 Digital Camera
Camera turns on and then right off immediatly
first if u want to get ur cam to work use energizer rechargeable batteries after charging them for sure this is the best kind u can use powerful and last longer ,to get ur pictures out u can take memory off the cam and put it inside memory card reader then plug it to ur computer through usb ,computer will read it easy and u can download ur pics to ur pc
Mar 27, 2009 | Vivitar ViviCam 3750 Digital Camera
Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Feb 25, 2009 | Kodak EasyShare C613 Digital Camera
My sony dsc-s650 does not work, ichanged out battery, memory stic
memory stick corrupt try formatting it on pc laptop card reader then try it
Feb 17, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Tv wont show picture at imes
Sounds like either the motherboard in the tv or the power supply has blown
Nov 17, 2008 | Toshiba 46H84 46" Rear Projection...
Kodak c613 will not switch on put in new batteries had this camera since xmas
What helped my camra to get working is to make sure you have the right battery.
the kodak easyshare takes only AA/lithium,AA/ni-mi,kaa2hr,AA/zr6 and AA/lr6 and akline too. It does not work for durecell batteries.Hope I helped!
Apr 09, 2008 | Kodak EasyShare C613 Digital Camera
Installing camera
run software again reattach camera after you restart computer
Feb 21, 2008 | Cameras
CAMERA WON'T TAKE PICTURES?
i don't know what age the camera is, did you try full batteries , normally it shouldn't do this it must have a defect if the batteries are not the problem..
perhaps contact the dealer see what is wrong with it..
Jan 03, 2008 | Olympus FE-180 Digital Camera
Camera a730
I changed the batteries to new fresh batteries i just bought and the camera wont turn on. just the green light flashes on and thats it
Nov 03, 2007 | GE A730 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
