Question about SanDisk Sansa e260 MP3 Player
Re-formatted Sansa e260 - still 1.4 GB (out of 4GB) tied up
I have a brand new Sansa e260 (from Best Buy). Put it in PlayForSure mode - had no interest in Rhapsody. Deleted all of the video / music / photo crapware that was pre-installed. 1.4GB out of 4GB still tied up. Reformatted the device. No change. Working fine otherwise - have copied over lots of music - but really want that 1.4GB back. I have the latest firmware too. Ideas???
  • James Morehead
    James Morehead May 29, 2007
    I'm going to try this suggestion from Sansa:
    Thanks again for calling SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
    There may still be music hidden in Rhapsody mode that you can't see.
    To find this music go to the Tools menu in the upper left corner from any open folder in Windows XP.
    Choose the last option, Folder Options
    A dialog box will appear, choose the View tab and you will see a list of options.
    Find and select the Show hidden files and folders option. Then click Apply, then OK in that order.
    This will make any hidden files on your computer visible.
    Now open My Computer and double click on the mp3 player to open it.
    You should see a few grayed out folders. We will be looking for MUSIC and SYSTEM.
    Open the Music folder to see if there are files there to delete.
    Open the SYSTEM folder and look for a second Music folder deleting this folder will free A LOT of space..all of the pre-loaded music for Rhapsody channels.
    Disconnect the device and check the free space.
  • 8,596 Answers
Posted on May 24, 2008
SOURCE:
I formatted my sansa e260 4gb mp3 player and now it says I have zero memory available.
get in recovery mode holding the record button and lock and power on. connect to the computer. a folder named 16mb format. create a new folder sansa.fmt and remove from computer. it will formatted correctly and will work fine.
Mar 13, 2013 | SanDisk Sansa e260 MP3 Player
Sansa e260 doesen't detect 4gb micro sdhc card
I will have to double-check the documentation that came with that specific MP3 player, but I know that some Sansas will only support upto 2 GB in the expansion slot.
Jun 09, 2009 | SanDisk Sansa e260 MP3 Player
Cant find music folder
Change USB mode to auto -IF it is avaialble in the settings menu - see manual for details.
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
Computer wont recognize the PlayForSure
Try getting windows media player 10 or 11
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Very new to this-got iPod, can I put songs on SanDisk?
I bought a sandisk and it came with best buy stuff loaded. Well best buy stuff expired and i have a lot of memory tied uop with it. I want to totaly reformat and remove all related stuff to best buy so I can start from scratch
Apr 10, 2008 | SanDisk Sansa m230 MP3 Player
Sansa E280 isn't recognized by Vista
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Mar 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e260
You can format the device in My Computer>Device Name (e260)>Right Click and select format.
If that does not work, change the mode on the device Settings>Mode or USB Mode and ty again.
Best of Luck.
Nov 07, 2007 | SanDisk Sansa e260 MP3 Player
Sansa media player 4gb
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
New player, says I ran out of space
If you formatted it thru Windows Media Player, or Rhapsody, it didnt really format properly. Make sure the device is in Rhapsody Mode. Settings>Mode or USB Mode>Rhapsody. On your computer go to Disk Management. Right Click on My Computer and select Manage. On the next window select Disk Management, under Storage. On the right side at the top of the window you will see the device listed (i.e. Sansa e250r). Right click on the device and select format. Dont select any other options, just hit Start. Your device is now formatted properly. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
77 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
