Tv keeps knocking off to standby mode
Stared a few days ago sound would go then knock off to standby mode however after unplugging for a while it would come bnack on however lalast night evrytime i turned tv on it kept reverting to standby mode
  • 6 more comments
  • badger2 Jan 08, 2009
    ke and mODEL IS TOSHIBA 32WL66P
    when i turn tv on there is no sound then immediately reverts to standby mode the power indicator shows red light not flashing whch is usual standby mode
    not that ive noticed, however if there is what could problem be?
  • badger2 Jan 09, 2009
    unloading the power supply, what does this mean, how do i do it?
  • badger2 Jan 13, 2009
    how can i disable the audio circuit?
  • Jason Morris May 11, 2010
    Can you tell if there is a quick flash from the backlight?
    You may have to make the room dark.
    Do you still have a picture when you llose the sound?
    Does the power indicator led on the front of the tv blink or flash?
  • Chuck May 11, 2010
    need make and model
  • 108 Answers
It is most likely going to be a defective power supply but there are some other circuits that can cause the problem. I would start by unloading the power supply.
Posted on Jan 08, 2009
  • Chuck Jan 09, 2009
    say for instance you have a shorted audio amp in the set, this would not allow current to flow to that circuit thus causing the set to shut down. If you disable the audio circuit then the current would be able to flow, allowing the set to work but with no audio thus identifying the audio pcb as the defective circuit.That is what is meant by unloading.
Knocking sound in tv pls. give solution
What kind of knocking sound?
What kind of TV?
Some TVs have small fans inside them to keep them cool which can get noisy when old or if something has got into them.
Or could it be coming from a speaker?
Not many things in a TV can produce a knocking sound.
Jul 17, 2017 | Televison & Video
How do I bypass a knock sensor on a 2000 Nissan frontier
The pcm uses the knock sensor to monitor for engine knocking, and adjusts ignition timing based on this. If there is no knock sensor present, you will wind up with a hard fault that will keep the check engine lamp on continuously. Also, the truck will go into a more conservative driving mode to prevent knocking.
The knock sensor for a frontier is not terribly expensive, but it is a pain to access on nissan v6s, under the intake manifold
Oct 12, 2014 | 2000 Nissan Frontier
Tv will not knock off or come on,keeps tapping
Sounds like you have some bad capacitors that will need to be replaced ... if you are not qualified to do it yourself and the TV is not a high end unit, your best bet is a new TV. As far as knowing if it is on or off ... unplug it, wait a few seconds and plug it back .... most TVs will be in the off mode when you first plug them in. So then you will know it's off.
Nov 25, 2013 | Sanyo DP42746 42 in. Plasma Television
Knocking sound from the tailpipe when car is warmed up, even after turning it off
the replacement pipe is most likely thinner then the original and the heat is expanding and contracting it
Oct 09, 2012 | Honda CR-V Cars & Trucks
Valves knocking after oil added, starts between 1800 and 2300 rpms, what do i need to check now
take it to a shop sounds like you burned up the engine knocking is not good in an engine
Dec 31, 2011 | Ford Mustang Cars & Trucks
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
make sure the shifter and the linkage are greased, if the grease got washed off it could be the problem.
Sep 05, 2008 | 2004 Jaguar X-Type
Televison & Video Logo
608 people viewed this question
Top Televison & Video Experts
