Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED
light and your outlet is live.1.Power cord - check the cord it might be opened (no
continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse-
sometimes the fuse fail because of the power
surge, replacing with new one will cure the problem, If this is the case I
would advice you to use surge protector/AVR (Automatic Voltage Regulator).
However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the
linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and
still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything
because there some fatalcomponents
stored electricity enough to hurt you with a simple mistake only. I would
advice you to look for a
professional to troubleshoot
the power supply. If you want to repair it yourself make sure that you have
necessary tools and test
instrument. First check bad solder joints(re-solder all
cold solder), leaky
electrolytic capacitor(sometimes it has bulged at the top but not all, you better
have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat
sink), open fusible resistor (caused by shorted regulator
Transistor/IC), shorted zener
diode.
You may also replace the entire power supply board, click this LINK.
Hope I helped you.
Thanks for using fixya.
Jdvillanueva
Hi Joseph,
Make sure that you replaced the fuse with exact ratings. Low
ampere ratings will not handle current as what the original fuse installed. If
still fuse keeps blowing after replacing with the same rating, this is an
indication that you have a short on the power supply section. It can't be fixed
by replacing the fuse alone. Short usually near the AC line where parts like
the following are present.
This is the common parts that
might be shorted and made the fuse blew. You may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
If you don't have necessary tools and test instruments, and
can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't
attempt to work in the power supply if you don't know the safety precaution.
You may also replaced the entire power supply board. Click this LINK to order online.
If you are near to repair shop, you may bring the power supply board to them and isolate the shorted parts, you will save some money rather than sending the entire unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
