Question about Everex gPC2 TC2512 VIA C7-D 1.5GHz 512MB DDR2 80GB VIA UniChrome Pro Linux gOS V2 PC Desktop
Copy from camera to hard drive erases camera
I couldnt copy photo and mpeg files from my stylus 720 camera to the hard drive in a gang drag and drop without erasing the files on the camera card. it seemed to default to cut and paste not copy and paste . is this a problem with the free Enlightenment file manager? is there a file manager on the gos gpc2 that allows copy from an external card that leaves the files on the card? it appears the default to cut and paste is designed to thwart music file sharing.
also i want a file manager that always posts the size and date of files, as in the Details mode of the windows manager.
  • 39 Answers
Ok... if it won't let you click and drag, here's what you do. browse to the folder where your mpeg files are on the camera. click on any one mpeg. Press Ctrl+a. All your files will now be selected. Press Ctrl+c. You now have copied all those selected files to your clipboard memmory. Now browse to the folder where you want the files to be copied to. Press Ctrl+v. Viola!
Problem solved :)
Also... Ctrl+x = cut. Alternatively you can hold ctrl while clicking on seperate files you want to copy/select.
Good Luck!
Posted on Jan 07, 2009
    Scholar:
  • 111 Answers
Http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1225&ct=28
Hope that helped out;
Alternatively instead of drag and drop maybe you should copy paste?
How do I move photos from my tablet to the SD card?
Download ES File Explorer. Locate the folder where the pictures are, long press each file or select all by default, copy and paste files from the table to the SD card within the tablet. Alternatively, you can connect your tablet to your PC and access it via the PCs file explorer in the same way you would enter files within your hard drive. Copy and paste the files or drag and drop from the table to your PC.
Sep 28, 2015 | Tablets & eReaders
Why is my nikon coolpix L26 not uploading my pictures
First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
Jun 19, 2014 | Nikon Coolpix L26 Compact
How can i get my photo off the camera on to the cmputer then print them
The best way to download photos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy photos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Picasa will also do a more than adequate job of printing your photos.
Sep 14, 2013 | Olympus Stylus 710 Digital Camera
Can not concted in PC
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Try these procedures to open the lens.
Apr 03, 2013 | Olympus Stylus 720 SW Digital Camera
I have a Olympus Stylus 1050 SW digital camera, How do I download photos to my computer?
May 27, 2012 | Olympus Stylus / mju 1050 SW Digital...
Need some examples as to use the cruzer
click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet:
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
hope this helps
Jul 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Camera trouble
Highly recommend skipping the cable route from the camera, and instead consider using a USB card reader to download your photos. Card readers are very reliable in downloading files, and are much quicker too. Simply insert the camera card into the reader, and then the reader into the USB port. The card essentially becomes a hard drive that you can copy/paste or drag/drop your photos onto your hard drive. Card readers are very inexpensive too. here's an example from Amazon:
http://www.amazon.com/Memory-Reader-Writer-MiniSD-MiniSDHC/dp/B000I4RFO2/ref=sr_1_11?ie=UTF8&s=electronics&qid=1231217329&sr=1-11
Jan 05, 2009 | Cameras
Can't download from Casio EX-Z120 to iPhoto on iBook OS10.4.11
1) Create a new folder on your Desktop or in your Pictures folder. This is where you will copy your photo files.
2) Click on File, then New Finder window. Size these finder windows so you can see both of them at the same time. In the second window, go to your computer, and then to the drive that represents the memory card in your camera.
3) Drag and drop to copy the files from the camera's memory card Finder window to the new folder Finder window, dropping the files into the new folder on your computer's hard drive.
4) Use command+tab to change back to iPhoto. Cancel from the import warning window. In iPhoto click on File then Import to Library
5) In the import dialog tell iPhoto to move the photos (not to import them in their current location) so that iPhoto puts the photos in the same place it put your other photos when it imported them directly from the camera.
If you can't do all of these steps, tell me how far you got, and what happened and we can take it from there.
Dec 27, 2008 | Casio Exilim EX-Z120 Digital Camera
Transferring pictures from Computer to the camera
This is best done using a USB card reader.
You just drag & drop or copy & paste files, just like you would do moving files from folder to folder on a hard drive.
USB card readers also transfer your photos from your memory card to the computer MUCH faster than from the camera.
Hope this helps.
Jan 10, 2008 | Kodak EasyShare One Digital Camera
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Everex gPC2 TC2512 VIA C7-D 1.5GHz 512MB DDR2 80GB VIA UniChrome Pro Linux gOS V2 PC Desktop Logo
90 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
