Question about Air Hogs Havoc Heli Helicopters
Problem with the back rotor.
The back rotor sometimes doesn't spin and when it does it isn't spinning fast enough so the heli just spins and crashes
  • superman8822 Jan 21, 2009
    no thats the first thing i checked. i think it's a problem with the motor. anyone know of anything i can do? or is it just broken and i need a new one?
Hey!
Replace the back rotor... I just did and both my havoc helis are flying like new...
Posted on May 31, 2009
    Problem Solver:
  • 11 Answers
Make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Posted on Jan 08, 2009
Crashed hard and now the bottom rotor is not spinning as fast as the other two. What should I do?
loosen the body screws. lift the right side front so you can see the engine gears, The little gear has slipped on the shaft and is not making contact with the big gear (white plastic gears). Slide the little gear down the shaft so it meshes with the bigger gear. Close the body back up (don't tighten screws yet). Turn the Heli on and make sure all is well (while holding the body closed). Tighten screws...Enjoy...
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
How do i get hair out of my tail blade
i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 29, 2010 | Air Hogs Havoc Heli Helicopters
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
Heli wont go up very much and turns to the left
If thi is a Reflex with two opposing rotors and two directional fans then use the "trim wheel" on the top of the rotor assembly to counteract the spin. If you crashed it often enough the shaft for the top rotor may have come loose. I'm not sure how this actually works with the trim wheel but mine crashed a bit and the shaft came out. I re-inserted it and it worked OK for a while but eventually the gear inside stoppped grabbing the shaft and the top rotor would not spin. I took it apart and tried gluing the gear to the shaft and that got the rotor to spin at the same rate as the lower rotor but I could not trim to get rid of the spin on the body. I would advise not buying the Reflex becuse it does not hold up very well. I went out and purchased a Sharpshooter which is easier to fly and seems more durable
Jan 12, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Spins to left non stop and trim wont correct it
Dec 26, 2009 | Air Hogs Havoc Heli Helicopters
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Helicopter spins left and rear rotor does not spin at all
Yes your motherboard shorted out. You need to get a new board or replace the heli.
Jan 10, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
Rotors spin just a little
make sure that the blades are snapped into place and that everything is charged and then make sure the heli is on because if you crash it, it will automatically turn itself off and then make sure no hair is stuck on the bar that spins thats attached to the blades and then try it again
Dec 26, 2008 | Spinmaster Air Hogs RC Reflex Micro...
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Air Hogs Havoc Heli Helicopters Logo
618 people viewed this question
Top Air Hogs Toys Experts
freddyfox
Stephan Reichert
Stephan Reichert
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
