Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Leak in power steering on Ford 5000 tractor
Leak in hose to Hydralic Reservor, we need to remove reservor to access hose coupling, how do we do it?
  • 45 Answers
SOURCE: power steering fluid coming up steer colume and leaking out on a ford 2000 tractor
Remove steering wheel, throttle cable and cowl . unbolt the top portion (4 bolts)of steering housing to expose shaft (DO NOT REMOVE THE STEERING BLOCK IT'S THE PIECE WHERE THE P/S LINES CONNECT) .Buy a top portion steering kit with seal and o rings replace them and button it up, Test for any leaks, if good you can replace the cowlect. It is a easy fix, the hard part is removing the steering wheeland cowl.
Posted on Nov 04, 2012
Toyota avalon 2000 ...steering fuild in reservor but steering really heavy why...thanks
Power steering pump pressure regulator is failing. Replace the power steering pump.
Jan 15, 2016 | Toyota Cars & Trucks
Braking system malfunction message appears when engine started
Could be a Vacuum leak to the power brake reservor. Time to see your reliable mechanic, dealer or possibly brake specialist. Brakes are important safty devices and repair soon is cheep insurance.
Mar 12, 2015 | Ford Fiesta Cars & Trucks
1996 dodge truck power steering leak out of bolt area
if it\'s the nut which looks longer than normal, sometimes located at the pump or at the hydralic fan, then the hose needs to be replaced. the nut in some cases can be obtained as a separate part, but it is a huge pain to remove the old one and usually angle grinders are involved..that\'s like a quick fitting connector and it has a couple of o-rings in it which allow the hose to move even when the nut is tight.
Mar 03, 2013 | Cars & Trucks
Location of vacuum reservor on 1988 ford mustang LX 2.3 liter
Fig. Fig. 191: Calibration 7-21C-R5-8-302 Mustang 1988 California
Fig. Fig. 192: Calibration 7-21C-R5-8-302 Mustang 1988
May 05, 2012 | Ford Mustang Cars & Trucks
Eps light keep coming on where is steering reservor
i presume you mean power steering reservoir should be under the hood small tank with dipstick in it when you remove cove
Feb 02, 2011 | Suzuki Swift Cars & Trucks
Cannot get calipers off FORD
BRAKE HOSE BOLT IS STILL CONNECTED YOU HAVE TO LOOSEN AND REMOVE BRAKE HOSE BOLT BEFORE CALIPERS COME OFF.THE COPPER WASHERS THAT CAME OUT WITH BRAKE HOSE BOLT HAS TO BE REPLACED THEY ARE SEALS THEY WILL LEAK IF REUSE THEM.
May 30, 2010 | 2004 Ford Expedition
My brake light has started coming on? Does that mean that the brake fluid is low? The brakes are not making any noise and they seem to be stopping ok.
Probably. If flushing and replacing the fluid (not just topping off) doesn't help, then take it to a mechanic.
Feb 10, 2010 | 1993 Ford Crown Victoria
Steering wheel problem???
Check and make sure that upper or lower ball joints are good listen for noise on the OUTSIDE of vehicle. Good Luck. thanks for using FIX YA
Jan 09, 2009 | 1996 Honda Accord
HOW DO I REPLACE THE STEERINGPUMP SEAL?
please what reservor are you talking about? the one for the radiator0 coolant? or what reservor, thank you, and on the shaft do you mean hose?
Jun 15, 2008 | 1992 Chevrolet C1500
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
1,028 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
nathan
Are you a RTO Garden Expert? Answer questions, earn points and help others
