Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
Cylinder head does the estima 2.2 diesel have more cylinder hed problems than any othet car
No more than others.
The problem is, the combined Aluminum Head and Cast Iron Block. The two metals heat up at different speeds and cool at different speeds, so expansion and contraction can cause problems.
The Mazda Bongo has the same set-up and also has problems. No more than any other car.
You need a a low coolant alarm fitting SEE HERE and keep your eye on the levels. Service regularly and keep on top of the up-keep of the car and you should be ok.
Posted on Jan 08, 2009
My 1999 mazda b2500 misfiring on cylinders number 1&2 diesel injectors fine . What could be the problem
Diesel ?? common rail or injector pump ,either way firstly i would suspect the head gasket as it sounds like its burnt through between cylinders one and two .This is the most connon fault with any engine
May 18, 2013 | Cars & Trucks
1996 toyota estima engine seized
If the starter is engaging and strong and with the vehicle sitting for nearly a month, I would tend to agree with your diagnosis. Water on the top of the piston. One sure way to find out is to remove all the spark plugs and turn the angine over. If this is the case, the water will exit the plug hole. If water does come out, you have a leak in the head or head gasket. Once the water is blown from the cylinder(s), you can reinstall the plugs and start the engine. If water is not the issue, you may have an even more serious problem.
Feb 26, 2013 | Cars & Trucks
Hi, The Toyota Estima 3CT-E motor that I have has a brand new cylinder head and Head gasket fitted but still getting water into #3 & #4 Cylinders. What can I check next or what do you thing is the...
There are several likely causes, none very rosy: 1) head is warped (was it surfaced and/or straightened in conjunction with the new head gasket?). 2) gasket damaged during installation. 3) head is cracked. 4) block is warped and/or cracked.
If you are committed to the car I'd recommend finding a re-manufactured head from a quality supplier and have it professionally installed. That covers 1 -3. #4 is very difficult to access without removing the engine from the car and taking it apart and having it magnafluxed. The only sure thing is a complete engine with a warranty. Cost of the reman engine is probably in excess of the value of the van.
Good luck
Mar 02, 2011 | 1992 Toyota Previa
Cylinder head torque spec lucida estima 2.2
help cant get a manual for our car, change head but unable to find the torque setting for it, its a toyota lucida estima 2.2 thanks
Aug 30, 2009 | 1997 Toyota Previa
How do i do an oil change on my toyota lucida estima
I believe you can find some guidelines in the following free download, good luck!:)
Contains:
Air Conditioner
Brakes, Wheels & Tyres
Cam belt
Central Locking Stuff & Alarms
Cooling System
Cylinder Head
Electrical System & I.C.E
Engine
Exterior Lighting
Fuel & Emissions System
Suspension & Steering
Transmission Systems
Also contains:
Estima Guide
Estima Owners Handbook
Download (~50MB): http://www.mediafire.com/?yx9wiypm6t2
Jul 25, 2009 | 1996 Toyota Previa
Hi i have a toyota estima lucida diesel and it chucks out smoke.
Is the smoke black-ish ?
It could be the fuel filters are dirty..
The oil cap might have the recomended oil on the top.. Or in your manuel..
To be sure - call you local discount auto parts store - and they will tell you..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | 1992 Toyota Previa
The problem is the water is linking ender the water pump's bolt
Maybe you can find some guidelines in the following free download, good luck!:)
Contains:
Air Conditioner
Cam belt
Cooling System
Cylinder Head
Engine
Exterior Lighting
Also contains:
Estima Guide
May 20, 2009 | 2009 Toyota Venza
I am looking for users manual for a toyota estima 2.2 1995 as the one i have is written in japanese. Where can I get an English version?
Try the following free download, good luck!:)
Contains:
Air Conditioner
Cam belt
Cooling System
Cylinder Head
Engine
Exterior Lighting
Also contains:
Estima Guide
May 02, 2009 | 1995 Toyota Previa
Estima starting problem
hi im rob r u looseing water white smoke indercates cracked head or blowen cylinder head gasket and the turbo wont provent it from starting turbos r just to give u more power
Apr 23, 2009 | 1993 Toyota Previa
Toyota estima 1995 model e-tcr 10g-rrspk
Contains:
Air Conditioner
Cam belt
Cooling System
Cylinder Head
Engine
Exterior Lighting
Also contains:
Estima Guide
Jul 27, 2008 | 1995 Toyota Previa
Car Audio & Video Logo
138 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
