Question about Canon IXUS V2 Digital Camera
My cannon Powershot SD500 has an e18 error message
So I took it apart and now Im not sure its enough apart or how to get it back together once I DO figure out how to fix it
  • 45 Answers
Hi prince,
try the following:
make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
there is a guide to dismantle it with pictures: try it:
http://www.fixya.com/support/t102982-e_18_problem
good luck!
Posted on Jan 07, 2009
E18 error
Here are some troubleshooting steps for a Canon e18 error. And here is a video summary of the steps:
Jan 19, 2013 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon powershot sd500 e18 error message
E18 is lens error , it means that the lens are stuck.
Oct 15, 2008 | Cameras
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
Camera won't shut
i would direct you to www.canon.com then... select support and find the manual for that camera... it should list error codes... if you cannot find it please let me know.
Robert
Jan 08, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
How can i ix the cannon message e18?
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
http://www.e18error.com/
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 20, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
I have the Canon Powershot SD500 camera and am getting the E18 error.
followed the link and tried his suggestions and hurrah! it worked for the same error message on CanonA400. Thank You!
Jul 31, 2008 | Canon Cameras
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
E24 code
Canon is replacing camera with a
CCD senor problem.......just got a new camera
go on their website and they will tell how to get it fixed
Nov 08, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon IXUS V2 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
