Question about SanDisk Sansa E280 MP3 Player
Mp3 player restarts whenever i skip a song
Hi there. I've recently had problems with my sansa sandisk 6GB mp3 player, it seems to turn itself off and restart whenever i skip songs. I've opened it up and taken the battery out and restarted it but still have the same problems. Also some songs i choose say that its a 'bad track' and won't play that particular file, and sometimes this freezes my mp3 player. I bought it brand-new over two years ago, and can't seem to figure out what to do. Any help would be appreciated :)
  • 282 Answers
Try using recovery mode with the sansa.fmt file and update the firmware. this will erase all your music from the device so you will have to reload all your songs but it will probably fix the issue.
Posted on Jan 07, 2009
Won't play certain songs
The device only likes mp3's. Mst other music files just don't seem to show up.
May 09, 2010 | SanDisk Sansa Fuze MP3 Player
Song's will not appear on Sandisk Sansa e270 (6GB)
Go to http://www.sandisk.com/ and search for your mp3's programming and download it, no promises, but it worked for my sansa fuze
May 13, 2009 | SanDisk Sansa e270 MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Skip's songs
It is on random mode- go into settings and change to sequential - read your manual, it is avalable on Sandisk's website:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
Skips
The songs are in the wrong format - convert them to Mp3 and you will experience no more problems - read my "Tips & Tricks" under my profile for more detailed info
May 21, 2008 | SanDisk Sansa c240 MP3 Player
Can't delete songs on my SanDisk m230 MP3 Player
Disable Auto-Sync in Windows Media Player before trying any other method.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 02, 2007 | SanDisk Sansa m230 MP3 Player
Hello!
Hmm well I don't know what to tell you about any of that since I am having problems myself with my own Sansa Mp3 player, but for the restarting song problem, did you check to make sure your mp3 player wasn't on repeat or hold? because if either of those operations were on then you would not be able to change the song with the skip button! Hope this helps!
Oct 29, 2007 | SanDisk Sansa e200 MP3 Player
Cant add/delete songs
it is just re-reading the songs
Apr 20, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
