Installing acces point
Is it possible to install two routers on one telephone landline?
    Master:
  • 409 Answers
It is NOT possible to have 2 Routers on one telephone line as routers do not connect to telephone lines. The typical home "router" is actually a modem connected to a router in 1 box.  You cannot have 2 modems on the same line (well you can, but they can't be both operational).  What you can do is have a router plugged in to the line and then plug a second router into it, giving you 2 "subnets" or, if the routers will support it, you could bridge them together to give you 1 subnet.
What are you trying to achive?  Is it just that you need more ports?  in which case just plug a hub in to the router.
Posted on Jan 08, 2009
    Scholar:
  • 95 Answers
Yes, you can chain routers together if you'd like, however people who connect to the first router connected to the modem will not be able to see the people connected to the chained router. However, people connected to the chained router will be able to see the other people connected to the main router.
Steven
Landline and internet not working
Follow the following steps:
1- Check your landline. If there is a tone signal or not. In case there is a signal go to step 2. In case no signal, contact your telecommunication company service center in order to repair your telephone line.
2- connect your telephone line to small device called filter signal. this device has one input (for telephone line) and two output line (one for your telephone system and other for ADSL your router)
3- You have to configure your router to connect to Internet.
For more details bout router configuration, contact me on ibrahimkt.78@gmail.com
I hope this help you.
Aug 04, 2017 | Internet Computers & Internet
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
Is there a way to connect the old landline phones to a router
I know of no way to do this. Try contacting Linksys (largest maker of routers) support and ask them, there may be an adapter to do this.
Sep 21, 2016 | EnGenius ESR300H - wireless router -...
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
Nov 02, 2017 | Linksys Wireless-g 2.4 Ghz Broadband...
I wish to register my landline telephone for online payment Kindly enlighten me in this regard!
Telephone the company that provides telephone-service to you, and ask for their Billing Department.
Jan 18, 2011 | Computers & Internet
I have a PC running with Vista and one laptot which we use the 160n for. The problem is when online an incoming or outgoing landline call will kick the laptop offline. Is it the setup? Thanks Lou
You need to check the signal to noise ratio.(SNR)
The telephone signal is probably causing this issue
Check with your telephone service provider to change the SNR
Jan 21, 2010 | Linksys WRT160N Wireless Router
When i use my landline i am being disconnected from the internet. can i change the linksy freq on the router
Do you have a filter on each telephone device attached to this telephone line?
One is required at each device or telephone when using a dsl router.
Jul 21, 2009 | Linksys Wireless-G WRT54G Router
Hot to use LINKSYS Router as an alternate wireless acces point
this is not a wireless repeater i do beleive this is what want. You need a router or gateway with this function. look at this product http://www.linksysbycisco.com/US/en/products/WGA600N
Feb 20, 2009 | Linksys Wireless-G WRT54GS Router...
Belkin FSD7230-4 Router
This is just a WAN router with wireless and 4 port switch.
It is not a DSL Modem.
In order to use this you need to use a Ethernet based CPE and connect the saem to this device.
Please find more information at the following URL under specification.
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=136493#
Jan 27, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
