Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
How do you replace cooling fan in M52W56LCD? where to purchase?
TV will not stay on red light flashes cooling fan not running
  • 43 Answers
Obviously, check the fan to make sure it is running. Second, see if there is anything obstructing the fan, and then make sure all filters and fans are clean and free of dust build up.
Posted on Jan 08, 2009
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
When i first turn it on, power light stays green. after 30 seconds, it flashes red and i get no picture or sound
Is this a led tv are a plasma tv?
If you have a power problem it may be the fans on the back of your tv.
If so take some Air-in the can blown the dust out of the cooling fans.
You may need to replace the fans if they are bad.
Thanks,
wbigtodd
Jan 22, 2011 | Televison & Video
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
I have the 50" SXRD XBR1 grand Wega; This has been a great set for 3+ yrs. A flashing red light promted me to replace my original buld (this site). I now still have a flashing red "power" light, shuts off...
Its the fan that cools the bulb. Try turning on the tv and look at the fan to the rear of the bulb. If the fan is not spinning that is your prblem. The tv has a safety switch that will cut off the tv if the bulb gets too hot. I was able to tap my fan with a pencil and get it spinning, but that is just a temperary fix. After a while, you will find the fan will stop working all together and it will need to be replaced.
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
Power Light Flashes 4 times on my KDS-A2000
Check the cooling fan directly behind the bulb. mine fan is going out. im having the same issue with the light blinking. when i get the fan on. the tv stays on until the fan stops, then the tv turns off.
Jul 14, 2009 | Sony KDS-R50XBR1 50" HDTV
Good sound, no picture, green standy light flashing
Replace the lamp-mine just went out also and sony told that I just need to replace the lamp---after a while the lamp indicator light will turn on red if and blink if this is your problem....also note to make sure it is your lamp unplug your tv from the wall or surge protector for atleast a minute or 2 and then replug it back in and see if the lamp light blinks red? If it doesn't then you got something else wrong. I hope this helps...if you need further assistance contact sony online via chat at sony.com and they'll help you fix the problem in no time. Take care
Mar 30, 2009 | Sony XL-2100U Projector Lamp for...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
223 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
