The unit is over flowing even when not turned on.
  • Mathew F
    Mathew F May 11, 2010
    What type of air con is it? Is it a evaporator cooler by any chance?
  • Ty Parcher
    Ty Parcher May 11, 2010
    That's very odd. Do you have a humidifier associated with it? If so it may have a stuck float value. Is it a gas unit? If the answer to both questions is "no" then it can't pull water out of the air to cause an overflow unless its actually chilling the air.
    Scholar:
  • 121 Answers
Hi! Pal
If this is a window unit you may want to make sure the unit is tilted so the outside is lower then the widow sill. Also, check the condenser as this will get plugged if a lot of flowering trees are near by.
Good luck, InMrFixIt
Posted on Jan 12, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If your air conditioner is overflowing with water
1. Check the drain at the base of the unit.
2. Check the drain hose post drain hole.
AC's condensate and create water and have to drain. If drain is clogged, they flood
Posted on Jan 09, 2009
Rinnai 24e
You need to check the water pressure and flow through the unit. It sounds like you dont have enough flow so it is shutting off.
Jan 29, 2014 | Water Heaters
AIR BLOWING LIKE IT'S ON FAN EVEN THOUGH IT IS ON COOL
close vent for outside air.....if not then probably lost its chaerge.
Oct 11, 2017 | Heating & Cooling
Switch on wall fireplace with Honeywell control SV9403, pilot does not turn on even there is current flowing into the controller device.
Good Evening. Your fireplace is equipped with a smart valve (SV) to which the valve itself acts as the control. This unit has intermittent pilot or hot surface ignition. Can you clarify to me which ignition this unit has?
Dec 30, 2013 | Honeywell Programmable Thermostat Heater
Unit keeps cycling off and on with the "bucket full" light blinking
It appears as if the water may not be flowing through the hose.
* When you use a hose the unit must be located near the drain. If the hose is to long the water will not flow freely and cause the water to back up in the hose triggering the bucket full.
* If the unit is lower or the hose runs up hill even the slightest incline will cause the water not to flow backing up to the machine
* Hose must remain flat and in a down hill flow to the drain if you are running a longer hose than recommended. If you are have a long distance to run the hose elevate the dehumidifieer by placing it on a stand, milk crate, anything that will hold the unit. Be sure it is large enough and strong enough to support the unit to prevent it from falling. This will help siphon the water from the unit and prevent any water to back up the unit.
* If your using an old hose make sure there are no kinks and water flows freely through the hose. Any kinks or type of pinch in the hose will cause the water to back up
I hope this helps resolve your issue. This is the most common mistake when using a hose.
Nov 30, 2013 | LG Dehumidifier LD650EAL
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Model330m no power
With the water at the hose bib on the side of the house turn on the unit and see if any water flows through. If not, clean the nozzle as it gets plugged up when not regularly used. Also be sure the REST button on the GFCI plug is pushed in.
Apr 28, 2010 | Karcher K2.26 Electric Power Washer
Rinnai R50LSi water heater- Water doesn't heat.
Flow meters can get jammed by silt or debrise. The only way that I know to check this problem it to remove & inspect the part and that takes alot of training if you have a Rinnai (not recommended for the beginner).
One thing you could check is the inlet screen. Turn off the water and power to the unit and drain down. The screen in the black plastic circle on the inlet fitting under the unit. Unscrew this and check how much grit it has collected. Clean off, replace, turn water back on, open a hot faucet to get the air out then turn the power back on. This sometimes improves the flow enough to solve the problem.
Apr 16, 2010 | Rinnai Water Heaters
WATER FLOWS IN, EVEN WHEN UNIT IS TURNED
Yup, the water inlet soleniod valve is bad....usually located on the bottom left under the dishwasher...
Kinda like this tip that I wrote only the reverse problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Apr 15, 2010 | Dishwashers
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
Heating & Cooling Logo
232 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
