Question about Mitsubishi WD-62825 62" Rear Projection HDTV
TV will not turn on
Mitsubishi DLP 62'', Green light under timer button keeps flashing and I am unable to turn the TV on.
Thanks
John N
  • 1 more comment
  • Anonymous Apr 02, 2009
    I have the same problem and have not been happy with the unit at all. There should be a recall of these sets.
  • Anonymous Apr 09, 2009
    green light over timer flashes;can't turn TV off; unplugging doesn't work;neither does reset button
  • Lashawn Robinson May 11, 2010
    Listen to TLM931
  • 273 Answers
Hello
the most common cause is the DM Module
there are capacitors that need to be replaced in the supply circuits
this is not a easy task and should be handled by some one that has experiance with this i would recomend finding a compatent servicer in your area that is capable and expect to 250 to 325 as a cost
the moduel can be exchanged verses repair but it exchanges at around 745.00
so its recomended to repair and your set should return to normal
Posted on Jan 08, 2009
The tv sucks and is a total ripoff . i have the same one.
    Problem Solver:
  • 17 Answers
I've worked on lots of these sets. Some lamp failure problems found:
#1. Busted lamp. Only had one that internal bulb broke. Check lamp first.
#2. Wear UV glasses for this test. This test should be done by a service personal.
Remove front panel and remove lamp door. Bypass switch by holding door swith closed with something that fits in whole. After green timer light stops flashing, hit the power button. Notice if lamp turns on at all for a moment or not.
If not, replace lamp and/or lamp ballast board, (if a known good lamp is being used).
If lamp does light up momentary before shutting down, then you must remove DM module and go through all electrolytic capacitors. Also, do not ingore the signal module. It too will have bad electrolytic capacitors from time to time, and have found on some sets that it was only the signal module and not the DM, however is recomended to go through both modules.
Posted on Jan 09, 2009
  • 179 Answers
The chassis needs to be rebuilt it will cost about $250.00
go to www.tv-techs.com
    Habit-Forming:
  • 166 Answers
The most likely cause is lamp failure this need replacing and they are quite expensive.
Super8
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
545 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
