Numark TTi turntable
Just installed the turntable with ez converter 2 - sound just repeats over and over like it wont advance or something - records are perfectly clean - I'm actually doing it for a friend and he has bought all the equipment - I'm really stuck and don't know what to do
  • hummingbird4 Jan 11, 2009
    thanks for the reply - the turntable has no model marked on it and neither does the books that came with it - there seems to be no serial number either which is weird - it is just marked Numark TTi with universal dock for Ipod. I have actually figured out that it was the counterweight not set perfectly. I think Numark should have this factory pre-set - its fine for people that know this stuff but not for newbies. I now have it set up fine and working thanks.
  • nuwan chinthaka
    nuwan chinthaka May 11, 2010
    what is the model??????
  • 476 Answers
Every DJ who use turntables will have set up the counterweight to suit the arms' balance on the record, (normally situated at the end of the arm is a counterweight system),This is used to adjust the pressure of the needle pressing down on the grooves on each record that is being played,
If not adjusted properly the arm doesnot travel the correct path on the record and seems to stop or skip at random,
The different sytles of performers seem to dictate the type of settings required by the individual users,ie,HOUSE,DANCE,TRANCE,HIP HOP,REGGAE,SCRATCHING,etc...............
The only other issue faced is the earthing of sound equipment,
If this is not done thru the correct methods then the systems will produce a horrible feedback noise,YUCK
We all apriceate a good sound and will enjoy a good mix of flavours the DJ can dream up to entice us all on to the dance floors.
Hope this helps resolve any misunderstandings,
Let me know if there is anything further I can help with.
Misterdj
Posted on Jan 19, 2009
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Find manual for Numark TTi turntable
This is likely the case if you hear no stereo separations and the vocals almost sound.
Jul 24, 2012 | Numark TTi USB Turntable with Pitch...
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
EZ audio converter hangs
not compatible with itunes 9 no solutiuon complain to numark turntables
Sep 16, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
228 people viewed this question
 Grubhead
Grubhead
