Question about Ziotek ATX Motherboard Standoff, 12 Pk (1610510)
Abit ip95 mobo
Compatible with intel core 2 quad? i have installed what will happen if i power up?
The answer is yes and no, up until March 2009 ABIT still testing some of Quad CPUs.
The most important things to remember are, socket type and BIOS update. You can go for all CPUs you can find as long using the same Socket, thats the point of different sockets, the compatibility is determined that way at the manufacturer level ( Intel n AMD ). The other is BIOS update, older BIOS might not recognize nor even support the CPU, this is more important than the socket type since you know you can put them in as long its a LG-775 CPU. So check the MBoard manufacturer to see if they have the latest CPUs recognized in their BIOS.
Don't be confused by the other answer about frying your MB due to power overload, it just a misleading, remember that some old CPU like Pentium with Prescott in them have TDP of 115 Watt while newer Quad like Q9550S with Yorkfield in them have TDP of only 65 Watt.
Posted on Jan 21, 2010
  • 144 Answers
You should really check these things first or consult the motherboard documentation which lists in great detail what the board supports
Get yourself a new manual if youve lost the one that came with it
ftp://ftp.abitshop.com/pub//manual/english/ip-95.zip
And to answer your problem , no you cant have a quad core
your specification says
"CPU - LGA775 Socket for Intel Core 2 Duo/ Pentium D/ Pentium 4/ Celeron D/ Celeron Processors with 1066 MHz FSB - Supports Intel Hyper-Threading Technology "
It would say "Intel Core 2 Quad" if you could
Try powering it up and it will probably either:-
a)Overheat
b)Spark and set on fire if theres not enough cooling
c) Cause a power cut , Quad cores take more power than the boards designed to support , otherwise they would have said i t supported quad cores.
d)Fry up the motherboard , making it useless
e)Fry up the processor , making it useless
f) all of the above
Posted on Jan 07, 2009
How Is a Q6600 core 2 quad cpu compatible with a foxconn g41 mxe-v motherboard?
Yes it's compatible. The type of motherboard can be any board that uses "Socket 775".
Aug 07, 2014 | Intel Computers & Internet
Intel E6750 compatible?
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
May 13, 2014 | HP Pavilion a6838f Desktop PC
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Oct 31, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Fatal1ty FP-IN9 SLi mobo - works great with dual core 65nm and orig mobo bios but upgrade to quad core 45nm and bios 16 and cpu fan makes lot more noise and I then get a chaecksum error and have repeatedly...
Not everything works with everything else. There will always be compatibility issues especially with motherboards and cpus. U have different circuitry, pin configurations, power requirements, ad infinitum.
Apr 08, 2017 | Abit Fatal1ty AN9 32X Motherboard
Is the intel core 2 quad compatible with my ddr2 memory
Hello.
The motherboard ASUS P5KPL-AM SE is compatible with DDR-2 no matter what processor you are using, even Intel Core 2 Quad. So if that is your motherboard, then it is compatible.
Jul 20, 2011 | ASUS P5KPL-AM SE Motherboard
Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
Apr 27, 2009 | Intel D945GCZ Motherboard
E8400 or Q6600
personally i have the q6600 which is a quad core processor, all the others you listed were dual core, personally i use alot of programs all at once which is good if you have a quad core, but just for general music, data, and streaming, the e8400 is probably better for you, its a 3ghz processor.
Mar 20, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
Abit IP95 Mobo fails to power up.
Ok, try connecting just one thing at a time - start of with just your board and the power supply... still smell burning? There's probably an issue with the power supply - no fans & leds would indicate this too (can you hear anything when you power up?)
What cooling have you been using - weird quetion, but is there any chance there could be moisture on the board? (either from water cooling or from condensation in the room)
Feb 09, 2008 | Ziotek ATX Motherboard Standoff, 12 Pk...
Ziotek ATX Motherboard Standoff, 12 Pk (1610510) Logo
328 people viewed this question
Top Ziotek Computers & Internet Experts
David Payne
David Payne
Are you a Ziotek Computer and Internet Expert? Answer questions, earn points and help others
