Question about Moen & Replacement Cartridge
Replace new moen 1200 stem, still leaks due to scratches housing
I replace new moen 1200 stem for shower fauce, still leaks due to existing scratches brass body housing (inside scratches by screwdriver). When I inspect the old stem, it had old rubber silicon around the stem, which I believed prevent this leak as before. I need to know what type of silicon or glue so I can fix this leak.Thanks.
    Novelist:
  • 148 Answers
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Posted on Jan 07, 2009
Remove stem of moen shower cartridge,
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
Jan 08, 2012 | Moen Plumbing
When faucet is fully closed hot water keeps on leaking.
You need to replace the valve stem. Turn off house water, locate and loosen handle set screw, remove cylindrical cover, and remove retaining nut to access stem. Take e stem with you to a home store or plumbing supply house for accurate relacement.
Oct 05, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My shower is running cold water only, the rest of house has hot water
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Sep 12, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Replaced stems and still leaking...
Hello Matg55,
If the seat came out with the stem, you will need to reinstall it.
The valve's disc needs a seat to seal properly.
Is the seat threaded on the side opposite the bevel?
Do you have a seat removal/Installation tool?
Kind Regards,
IT_handyman
Oct 20, 2008 | American Standard Bath Faucet Ceramix...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Moen & Replacement Cartridge  Logo
585 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
