Washer keeps stopping and often won't empty
It fills, then stops. I either turn it on and off or move the dial forward a little and then it starts again. I keep doing that  and occasionally it eventually finishes. But lately it won't start again to empty. If I empty the machine (via the filter opening at the bottom, right corner) it will usually start again by itself. I can't really afford a new washer, but then is it worth having it repaired? Is there anything I (unskilled in these matters) can do. Thanks in advance
  • 15,935 Answers
Replace the timer. It has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whdre526e1ww won't stop filling
Does the washer continue to fill if you turn the dial to the off position or does it keep filling when starting a load?
Oct 17, 2012 | GE WDSR2080D Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
The washer turns on, fills with water and starts to agitate...then never stops. It just keeps agitating till I turn off switch. The switch/dial never seems to move.
Its seems to be the complaint of the board. You can locate it beneath the unit but those things are so complicated and can be repaired only by a professional. Sometimes it may be needed to replace it, but in that case, it will be expensive.
Aug 20, 2010 | Frigidaire FEX831CS Top Load Stacked...
Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
May 31, 2010 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Tromm does no stop filling
you got water in the pressure valve hose ,,,,, keep running in on drain till it clears or the best it to remove the top of washer, pull off the little hose and blow thru it to clear it
Oct 19, 2008 | LG WM1814CW Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
