SOURCE: propane conversion for cozy model CF503C
try national energy for a conversion kit they should be able to help or the will know some one who can
SOURCE: Cozy wall furnace (propane) does not respond to
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
SOURCE: Need Help!! I have
put a jumper wire accross the 2 TH terminals if lights up the generator and valve are good could be safety or stat and stat wire.
SOURCE: Cozy WOW 234 wall direct vent makes loud whistle
remove the back panel and check the blower for loose screws or debris like sealant tape. and the third pipe is the fresh air intake.
SOURCE: The pilot will not stay lit in our Cozy Direct
There is a wind shield for this unit, call 502-589-5380 and ask for a drawing for the wind shield and have it made out of 26 gauge sheet metal.
