Question about Bosch Power Tools Sanders Orbital Sanders
Orbital sander flicking the sand paper off
I have a Bosch Pex400 AE orbital sander constantly flicking the sand paper off.
I am sanding the paint off a barge board on the house using a course sand paper (60 grit). i need to do this as the paint is flakey
I have tried using all the speed settings to see if it is speed related, without success.
Any suggestions, would be appreciated.
Thanks
  • 3 more comments
  • warped_79 May 04, 2009
    I have the same problem - the sander is brand new, and I've been using it for about 30 minutes. I get about 2 minutes sanding out of a brand new pad before it gets flicked off. The sandpaper side of the pad is still practically brand new. Once it's been flicked off it will not stick again and I have to start again with a new disc..
    I have tried cleaning both the sanding disc, and the velcro pad on the sander with a brush with no success... I'm about to return the sander back to Bunnings and try a different model
    My brand new Bosch orbital sander flicks off a brand sanding disc after about 2 minutes of use. The disc will not stick back on (like the velcro just doesn't grab). I've tried cleaning the disc and the sanders velcro pad with no success.
    Once the sanding disc has come off the velcro it won't stick again and I have to grab a new one and try again.
    I'm about to return this thing back to Bunnings and try a different brand (I got the $100 bosch one thinking it would be better quality than the $40/$50 ozito's)
  • Anonymous Mar 21, 2014
    5inch De walt palm sander rpm slows to allmost stop speeds up with less pressher
  • Anonymous Mar 25, 2014
    need to know how to remove sanding pad and paper and replace with new
  • d milich
    d milich May 16, 2016
    After reading all the comments about Bosh Pex400
    I refused to go and buy a new pad...$28NZ...found some Hooks in my wife's draw and glued 6 strips across the pad....and ques what....it works like a dream.... just finished 2 hr of solid sending and not
    ones the paper come of.....whats more I had a prob puling the paper of to put the new paper on.....Bosh....wake up....you got it wrong with this machine...
    Scholar:
  • 58 Answers
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
Electric Sander
Get a good 5" random orbital sander with hook and loop paper. They are easy to handle while on a ladder.
Jun 26, 2009 | Tools & Hardware - Others
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
Orbital sander
You should really take it back to place of purchase and get it replaced/fixed under waranty. If you try anything other than checking the fuse you will invalidate the warranty. Most manufacturers allow retailers to replace faulty tools within seven days of purchase. Be sure to take your receipt with you as a copy will be needed for the shops warranty claim.
Sep 23, 2008 | Bosch Power Tools Sanders Orbital Sanders
Air sander Support
You can add different sanding discs to an orbital air sander to ensure that it is properly set up for a huge variety of different jobs. From heavy duty sanding paper for tough jobs through to buffing cloths in order to get a final polished finish at the end of the job. With most orbital air sanders, changing the disc takes just a few seconds, allowing you to get a variety of jobs done a lot quicker.
Aug 27, 2008 | Chicago Pneumatic C-P AIR SANDERS & FINISH...
Bosch Power Tools Sanders Orbital Sanders Logo
5,291 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
