Question about Nikon N50 35mm SLR Camera
Nikon N50 SLR film
When I turn on my camera the screen reads error and shows the film symbol and underneath the film symbol shows min. Even when I put film in my cmera it still reads error. Sometimes the error signal will turn off but it can not read the film it seems like it winds too much of it at once. PLease Help!
  • Anonymous Oct 12, 2008
    Hi, i have the same problem i think, when i turn on my camera, it shows Err and next to this, appears the film symbol and below the word MIN. Please help me i dont know what to do!
  • Cmartens Nov 13, 2008
    I have the same problem. When I turn the camera on and try to take a picture it says error min and has an M over the number of pictures I have taken which is none so far, and I already have the film loaded. What should I do?
    Problem Solver:
  • 5 Answers
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
Posted on May 29, 2007
    Problem Solver:
  • 15 Answers
You may want to try resetting the wind mechanism. With no film in the camera, close the film door, turn the camera on, push both rewind buttons at the same time. Hold the rewind buttons in for a few seconds and the camera should go into rewind mode. If it does, it will run for a few seconds. When it stops, open the back, re-insert the film and it should wind correctly. If it doesn't, the camera needs repair.
Posted on May 30, 2007
How to load Nikon F50 camera
The F50 is called the N50 in some parts of the world.
The film loading instructions are on pages 10-11 of the N50 manual available from http://butkus.org/chinon/nikon/nikon_n50/nikon_n50.htm
Jan 28, 2014 | Nikon FG 35mm SLR Camera
SONY CAMERA RATE MODEL NO.N50
To my knowlege, Sony did not make an N50 camera. They did make a VCR, the SLV-N50 and ratings for that can be found here:
http://www.amazon.com/Sony-SLV-N50-Stereo-VCR-SLVN50/dp/B00004VW2A
Nikon made an N50 film SLR beginning in 1994. 30 reviews on the Nikon N50 can be found here:
http://www.photographyreview.com/cat/cameras/film-cameras/35mm/nikon/n50-f50/prd_84794_3105crx.aspx
Hope that helps,
Bax
Oct 10, 2013 | Photography
On the screen it shows ERR and what looks similar to a recycling sign and then it says MIN under that sign.... can you help??
Check to make sure the aperture ring on the lens is set all the way on the highest f number. (it's usually red)
That problem is in your manual's troubleshooting matrix.
Feb 28, 2010 | Nikon N50 35mm SLR Camera
Flashes Err followed by a circular symbol with min under symbol
The lens is set incorrectly. Set the aperture ring on the lens to f22 or 32 what ever the biggest number is on that aperture ring and lock it. It would work now.
Oct 08, 2009 | Nikon N50 35mm SLR Camera
Err min Message
This can happen if you are using a non-G lens, without the lens aperture being set to the minimum aperture and locked.
Sep 09, 2008 | Nikon N50 35mm SLR Camera
Error message
Hey there deliafuentes, I would suggest you check your film to ensure it is seated correctly and fed across to the orange line inside the winding post on the right side of the open back of the camera. If this is not the problem, I would check the settings to ensure you are not in a protection mode which will prevent you from snapping a picture which is not properly focused or without the necessary light required. Try turning off the auto features to test the possibility. Another option is the batteries may have insuffient power to drive the features which you are using. Switch to a new set, preferrably not rechargeable or generic. Good Luck!
Jan 28, 2008 | Nikon N50 35mm SLR Camera
MY N50 CAMERA IS FLASHING ERR
yes in order to fix this camera you need to replace the film transpot unit assembly and re-adjuster youre camera to factory ****. MIKE REPAIR TEC.
Oct 27, 2007 | Nikon N50 35mm SLR Camera
Slr camera's lcd screen only says i have taken 3 pictures, and keeps sayin ERROR, what could be wrong? I tried replacing the batteries and the camera still says ive only take 3 pictures, even when i out...
Try resetting the counter by pushing and holding the two rewind buttons simultaneously ( red symbols ), one on each side of the top cover. Then open and close the film door.
Sep 23, 2006 | Nikon N65 QD 35mm SLR Camera
Camera flashes "error" when turned on
Check if the aperture is set on anything other than 22. This would generate an error message. the N50 (and other auto Nikon cameras) needs to have the lens aperture set to the smallest -- AutoFocus lenses have a lock on them to lock the aperture at the smallest. Some models, such as the N5, can be set to use either the lens' aperture ring or the camera's command dial to set the aperture, but most simpler Nikon auto cameras can only be set by the camera. Setting the lens to its smallest aperture tells the camera that it can control the lens. If the lens is set to anything else than the smallest aperture, F-- shows up on the camera's LCD, and the camera locks up. Check your camera manual for complete info.
Mar 05, 2006 | Nikon N50 35mm SLR Camera
Nikon N50 35mm SLR Camera Logo
440 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
