Question about MSI K8MM3-V Motherboard
WARNING!YOUR COMPUTER CASE HAS BEEN OPENING.
The built-in speaker is always beeping like an ambulance beep.
  • 535 Answers
Chak your ram its has been bad or damged
Posted on Jan 07, 2009
I got a message on the desktop "My computer case has been opening" and also start beep continuously.
Posted on Jun 18, 2011
Dell working but continuos beep sound
beeping sounds are warning to users that computer parts need servicing, it may be memory cards , hard drive , fans or power supply, call tech support if system is still under warranty.
Jun 05, 2012 | Dell Case Fan Assembly for PowerEdge 2800
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
P5KPL-AM speaker beep
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Take care!
Dec 16, 2011 | ASUS P5KPL-AM SE Motherboard
Mother board does not make beep sound
this could be just about anything. Check to make sure the power supply is plugged in to all the correct ports, check to make sure the RAM seated properly.
Mar 05, 2011 | Intel Motherboard
I just built a system with a gigabyte ga-ma785gm-us2h mb with an athlon2-x4640 processor. it does not post. keyboard, fans and hd power up,but no display or beeps. tried clearing cmos but no change. ...
hello ddkkdd
my name is ausi. i just saw your issue with the motherboard. if you have not solved the problem yet then do the following
1- your motherboard does not have a built in speaker. make sure you have one connected in case there is beep. short rapid beeps are memory problem and longer ones the video card.
2- after you turn the computer on press the power button in front the case again (couple of seconds only). if the computer does not power off then most likely problem is the main board.
alternately if you purchased the lot from the same place take only the motherboard and processor back to them (assembled) and ask them to power it up for you.
good luck
Jan 09, 2011 | Intel Motherboard
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sola 4000 battery back-up system beeps
You need a 12 volt 17 AH battery
www.budgetbatteries.com
Aug 22, 2009 | Logitech Z-5500 Computer Speakers
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
Jan 07, 2009 | MSI K8MM3-V Motherboard
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
Problem with my newly built pc
Hello!
The information for that specific motherboard lists beep codes for 3 beeps or 4 beeps. 3 beeps signals a memory error, 4 beeps signals a thermal warning.
The PDF is here.
Additional information on beep codes can be found at this site.
Hope this helps! If not, let me know and I will try to find more information.
Jan 19, 2008 | Computers & Internet
MSI K8MM3-V Motherboard Logo
1,892 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
