Question about Freezers
Got another question about a freezer
Hi. You helped me with the washer machine a couple days ago and thanks a lot again. Do you know anything about upright freezers, specifically Frigidaire/Tappan freezers? If so the freezer isn't freezing anymore and we can't figure out what's wrong with it. Would it even be worth repairing? And the product line won't be correct because it won't recognize the product so I'll give it to you here.
Frigidaire 11.7 cu. Ft. upright freezer model # 4124305/TFU12M4AWO
  • Freezers Master
  • 856 Answers
I have seen freezer stop working because the owner pulled it out to clean behind it and pushed it back into place too far. This "Chocked" the air flow around the condenser and caused the failure. Be sure condenser is clean and air can circulate. Older units have coils up the back and newer ones have them underneath and utilize a fan. You can use a vacuum on the the underneath ones. Be sure fan runs under there.
Posted on Feb 09, 2009
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
True Freezer T23 compressor will not stop running
Have him check the t'stat. And freon lines. I believe the t'stat is the problem. Are the door gaskets ok and does it seal properly when closed. The fan should always run, so this could be in the rewiring. I am assuming you will be working out of a freezer where the working temp is a little higher.
Feb 16, 2013 | True T23F Freezer
Glfh21f8hw freezer - tried to bring the temp down off extreme freeze and it went off (display shows OF and compressor stopped). Just loaded it with lots of food, can't get it to come back on and the...
At 0F it will go off because it is at 0 so it is ok later when it warms up again it will start up and bring the temp down again. Just check your temp for a couple of days so you have it at the right temp.that you need it at. It should be OK at 0F
Dec 06, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Icemaker Waterline has Bacteria in it
This bacteria (for most of us) is not harmful. Ive never heard of anyone becoming sick from this stuff but I suppose someone might have an allergy. I see it in Ice Machines that are in restaurants all the time. It seems more prevalent in ones that do a lot of baking where yeast or Bread is used a lot like Bakeries Pizza and Hamburger fast foods...places.
Do you store a bread doe in your refrigerator? The air communicates with the freezer air. This is how its transferred. Clean the reddish stuff out again. Clean and wipe the outer containers and the walls and ceiling and under crisper in the refrigerator. Then if your going to store anything that you use with yeast or other types of activator that puts off CO2 (I E Baking soda or power?) double bag it in plastic bags. See if this solves your problem. If the stuff comes back it must be in your water supply. Are you on a treated water supply?
Hope this helps if so please rate me accordingly and good luck.
Feb 10, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Jan 21, 2008 | Freezers
Freezers Logo
212 people viewed this question
Top Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
