Logon cant logon to windows XP I can see a startup screen with the Windows Logo but the log on screen doesn't come up. The computer gets out of the BIOS startup but only a blank black screen and the arrow cursor would appear after it started up.
    Scholar:
  • 111 Answers
Go into your BIOS
Set the 1st Boot device preference to CD
Insert your windows XP disk
Boot from CD
Run XP Repair
You do this at your own risk. I am in no way accountable for damage to your computer.
Give me a message if you need further assistance
Blazamane
Posted on Jan 07, 2009
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
How can i log in my Delloptiplex 760 computer,when its auto logging off
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 PC Desktop
Icant log in my computer.when log in,with in few seconds it logging off automatically
If running XP
or
or
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 MT Desktop Computer
When istart the computer cant log in ,eventhough my user name and password is correct
or
or
Hope this helps
Nov 13, 2012 | Dell OptiPlex 780 MT Desktop Computer...
Forgot password SuperMicro SuperWorkstation 7033A-T
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 21, 2012 | SuperMicro SuperWorkstation 7033A-T...
RECOVERY FACTORY
Hi there!
Here are the steps to restore your computer to factory default:
Windows XP
- Turn on Computer
- during startup you will see the Dell logo, press <Ctrl> <F11>
- click Restore then Confirm
- let the computer finish starting
Windows Vista
- Turn on Computer
- during startup you will see the Dell logo, press <F8> several times
- select Repair your computer
- select keyboard layout then next
- log-in as local user
- click Dell Factory Image Restore
- Click Next and confirm data deletion
- wait until it finish
Apr 11, 2011 | Dell Vostro 1710 Laptop Computer PC...
I have an HP tower pc running windows XP. It's about 4 yrs old. The problem is that I cannot login into windows. I get the following message: "This copy of windows must be activated before you can...
Assuming that you didn't do a fresh install of windows, Do this:
When the blue screen with the HP Invent logo
appears, press the F10 key on the keyboard. (You
have only a few seconds to press the F10 key
before the normal startup process continue
Then Select Full System Recovery (which will erase whatever you had in computer such as personal files, etc). Pretty much your system will be back as Factory Image
Thanks
DiegoTech
Nov 14, 2010 | HP Pavilion a1130n (PX769AA) PC Desktop
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
Logon
Can you describe the issue ion more detail?
Do you see a startup screen with the Windows Logo? Does the logon screen come up? Does the computer get out of the BIOS startup?
Nov 19, 2007 | Compaq Presario 7478 PC Desktop
Computers & Internet Logo
126 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
