Question about Acer Aspire 3680 Laptop
Memory upgrade for Acer Aspire 3680
I am upgrading the RAM in my laptop. The Acer E-settings management utility included with the purchase of this thing says it supports a maximum 4gb. I bought two sticks of 2gb Crucial brand memory. Either stick works well in either slot on the motherboard but the machine stops working when I try to install both sticks at the same time. Do I need to change something to make both work or is the maxonly two gig?
  • dshaw_01 Jan 07, 2009
    Thanks jonniewalker sure does help. Another question. The 2gb sticks I bought work but only 1 at a time in either slot. My settings utility says the memory is 2gb in slot 2 no matter which slot it is actually in. The machine supports dual channel but came with only 1 512mb stick. Will using the single stick of 2gb memory harm anything?
  • 1,031 Answers
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot so you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS hope this helps pls appreciate by rating as fixyaa.thanks and Godbless.
Posted on Jan 07, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 07, 2009
    To benefit from the performance advantages offered by dual-channel systems which your computer support you should install memory in identical pairs. Installing a kitted pair is the best way to ensure that your modules are identical, right down to the chip count and also check the bit version of yuour operating system
    The maximum amount of memory that your system can use is actually limited in two ways — not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept.
    For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used only by high-end users), your system will see (and utilize) only 3GB or 3.5GB. Is the problem bad memory?
    Relax, there isn't a problem with the memory. Windows allows for 4GB of memory to be addressed, but this isn't 100 percent the same as having 4GB of physical memory.
    What happens is that some of the addressable memory (regardless of how much you have physically installed) is reserved for use by page files or by some of the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc., so it's unavailable for use as normal main memory.
    The amount of memory needed for these devices is calculated by your system at startup; if you haven't maxed out the memory in your system, it's invisible to you, and all your physical memory (the RAM that's installed) is available for use. However if you've maxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM.
    The maximum memory limitation varies by operating system; for instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
    Memory maximums for current Microsoft® Windows OSs include:
    • Windows XP Home: 4GB
    • Windows XP Professional: 4GB
    • Windows XP 32-bit: 4GB
    • Windows XP 64-bit: 128GB
    • Windows Vista Home Basic: 4GB
    • Windows Vista Home Basic 64-bit: 8GB
    • Windows Vista Home Premium: 4GB
    • Windows Vista Home Premium 64-bit: 16GB
    • Windows Vista Ultimate: 4GB
    • Windows Vista Ultimate 64-bit: 128GB+
    • Windows Vista 32-bit: 4GB
    • Windows Vista 64-bit: 128GB+
    hope all this helps .goodluck any further problem you let me know
Get black screen after upgrade Acer 3680
might be that the ram you got was the wrong ram for that laptop.not all ram work in all laptops.
May 23, 2014 | Acer Aspire 3680 Laptop
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Installing ram memory
well inserting another memory in a laptop needs a techical assistance but if you're willing to do it on yourself, unscrew the bottom of the laptop then find the small rectangular bar around and you can see the empty slots beside it, that is where you should insert the memory then put everything back into place and there you go.
any queries?you can ask me again
thanks and God bless.
Jun 02, 2010 | Acer Aspire 3680 Laptop
How do I upgrade memory?
what kind of memory hard drive or ram?
Jan 17, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 3680 notebook with 512mb Ram.What type of Ram do I need to upgrade
it must be DDR type of Ram. dont use DDR2 ram.
you can use 1 GB DDR of Ram
Oct 12, 2009 | Acer Aspire 3680 Laptop
Adding memory to Acer Aspire 4720z
The RAM memory slot is up on battery .
First open cover above battery plate then fix RAM there .
Jul 13, 2009 | Acer Aspire 4720 Notebook
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Graphics upgrade
if you have Aspire 3680, the answer is no, you can't upgrade graphic card, because it is on motherboard, it isnot like desktop computer (separate card).
Mar 29, 2008 | Acer Aspire 3000 Notebook
RAM ON acer computers
Yes... just need to purchase the right stuff.
You need to determine if you have DDR or DDRII. And then determine if you have one stick of 512, or if you have 2 sticks of 256. Once you know this information, visit your local Best Buy or purchase somewhere online, a memory upgrade. Such as 2 sticks at 512mb for 1 gig total. Assuming you have two memory slots, should have anyway.
DDRII is fairly cheap right now, be a good time to upgrade. DDR on the other hand, is still a little more expensive.
Oct 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
491 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
