Question about SanDisk Sansa Clip MP3 Player
My sansa clip was fully charged and i push the formatt button by accident. then i was changing the radio station to japan and it just turned off and it will not turn back on what did i do . how can i fix it
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
Bought Sansa 2GB mp3 player and can't work radio
Dude I have one in front of me so listen and follow along first turn the unit on, second push the menu button, this is the very small buttonright to the right of the SANSA namewhen you push that button the first thing you will see is the words MUSIC while thats on the screen hit the play button that looks like this >|| and you will scroll through all the settings you will see the fm radio selection when you get to it hit the middle button and the radio will come on.
Mar 21, 2009 | SanDisk Sansa Clip MP3 Player
I have a sansa clip mp3 but i can't turn on the fm radio. help
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip - not able to playlist listen on car radio w/ adapter
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
I can't seem to swithc from radio to playlist mode
Push the little black button with the "Home" key and turn the wheel to the headphones. Now push the black button in the center of the wheel.
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Wont turn on
did you try pushing the little button on the side towards the on positition. It should be in the middle by default. If you push the button down, it locks the songs so they can't accidentally be deleterd. But to turn it on you need to push the button up and quickly let it go. Don't hold it or it will turn off again. Then to turn it off when you are done you push that button again and hold for about 1 second. I hope this helps. You didn't say if you tried that so I am assuming you didn't.
Nov 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging the Sansa Clip player
If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully charge...it should take a couple hours to charge the device....
Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
