Question about Whirlpool GSC9455 Top Load Washer
Spin cam bar seem to be stuck..is the clutch the problem
TThanks TZWEEB you were very helpful. I can't get my hands in there because I have access to only lower back. I dropped the motor down a little by removing the back motor mount plate. I wasn't able to pull spin cam bar al the way out. Doesn't the large end go thru the clutch so I won't be able pull it all the way out and replace it without removing the transmission. I am replacing the wigwag but I think the old is working . When I pushed the spin cam bar all the way back the spin would stopped but would not spin unless I pulled it back. IT DOES MOVE BACK AND FORTH EASILY as the agitator cam bar does...is that normal. That is why I attemped to pull it out. Is something in the clutch not allowing it to slide back and forth easily. I have to push so hard that I don't think the wigwag could push it back and forth. I bought this machine in 1982 and I hate to give up on it. One other thing I used lithium lube on the cam bar was that a mistake..will that effect the magnet?
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
  • 1073 Answers
SOURCE: Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Posted on Apr 16, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Ultimate Care Washing Machine Agitator
after removing the agitator from the machine (7/16 bolt) i place the agitator on the floor, step on either side of it and pull up on the top half, ittl come loose, needs a little help! a word of advice though is after replacing the agitator dogs, turn the entire agitator upside down and insert the bolt through the entire agitator assy and keep constatn pressure on the bolt as you turn it boack over and try to realign with thte tranny shat. ( you see the parts wanna seperate as you try to reinstall them otherwise)
Posted on Oct 27, 2008
huuum
  • 750 Answers
SOURCE: One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Posted on Apr 07, 2009
Clutch removal on a580-531060 craft an chainsaw
Assuming you want to remove the clutch spider, which typically is left-hand threaded onto the crank. Not knowing if it's an internal (chain drive sprocket is "outboard") or external clutch, here goes for both. After removing bar & chain.
Internal: CAREFULLY (so it doesn't fly) remove clip from crank, remove washer, clutch drum, bearing and/or rim sprocket. Remove recoil starter. Using proper tool to fit clutch "spider" and impact wrench, turn it CLOCKWISE with wrench to unthread it.
External: Remove bar & chain and recoil starter. Using tool to fit the clutch "spider" and socket on impact wrench, spin the spider off CLOCKWISE. You can then remove remainder of clutch & bearing.
Be sure to grease the bearing while it's accessible.
Starter removal avoids applying any load if the crank turns.
Jun 05, 2016 | Garden
My Whirlpool Duet front load washer makes a clicking/grinding sound when you start a cycle. The drum never spins, sounds like a plastic gear or something.
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
Read more:http://forum.appliancepartspros.com/washer-repair/506592-grinding-noise.html#ixzz3ZrrG7UEk
Feb 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My toyota 4runner v6 engine seems to be stuck
Check the pulley behind the fan clutch, remove the belts and check for a seized pulley, the fan should spin by hand with the pulley.
Feb 25, 2013 | 1995 Toyota 4Runner
Pressure plate and clutch plate is stuck together
You might be able to take the starter out to access the flywheel and use a pry bar to break them apart. You could also have a failed slave or master cyl.
Dec 07, 2012 | 1988 Toyota Pickup
Will wash clothes but not spin them dry
This is a little about how your washer spins. When time to go into a spin cycle, the motor is already running and the washer is in a pump out mode. The timer advances and closes contacts in timer that make electrical circuit through the lid switch to the spin solenoid. This is normally done through a gray wire from timer to lid switch and then a red wire from lid switch to the spin solenoid. A white common wire completes the circuit. This spin solenoid is on a magnet bar with the agitate solenoid also on it. You will see it under the machine moving back and forth as the motor runs. This magnet bar is called a wigwag in the appliance trade. When the spin solenoid is energized, it sucks a plunger pinned to the spin cam bar up into the solenoid. The plunger pin goes to a different level in the cam bar and pulls it in the direction of the motor and keeps it there until spin cycle is over. When cam bar is pulled back, it allows the clutch to drop down and engage the spinning center pulley attached to the spin tube. The spin tube turns, the wash basket is locked to spin tube, therefore it spins. Now for your question. What goes wrong?
1. The solenoid can be open. Watch it and if it doesn't **** the plunger up, check with an ohm meter. If solenoid good, assume no power to it.
2. No power to solenoid. You will need to check the circuit from timer, through lid switch, to solenoid. Most likely place seems to be lid switch. check it.
3. The wires coming to the solenoid are constantly moving back and forth as the machine runs. This puts tension on the wires and they tend to break inside the insulation of the wire. To check for break internally in the wire, read from one end of it to other with ohm meter. Another way is to grasp wire (unplug the washer) about 8 inches back from end and pull hard on end of wire. If broken inside, it will pull apart and stretch insulation. Replace wire. There are mechanical operations that can give problems, but most spin problems are in the area that I just addressed.
Another common trouble maker has cropped up in the last few years. The set screw on the clutch assembly backs out and this will keep the brake on all the time and the washer will either spin very slowly or not spin at all. Sometimes the hole in the spin tube will become damaged and requires the clutch to be replaced, but sometimes the sets screw can be reinstalled. (unplug the washer) You must remove the set screw and line up the holes by slowly turning the inner basket around. I usually use a piece of hard wire pushed into the hole, once the set screw hole and the spin tub holes are lined up you will be able to push the wire in...add some lock tight to the screw threads and reinstall the set screw. Picture of where this set screw is.
Nov 27, 2009 | Kenmore 24902 Top Load Washer
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Whirlpool top load belt driven commercial
there is no easy way to put the cam bar back under the pressure spring. what i usually do is try to start the cam bar at the short end and force it back under without removing the bolt that holds the spring to the transmission. if you cant figure out how to do this the only other way is to remove the transmission.
if you do take the trans. out then be careful to not let the agitator shaft ball fall out or the unit wont spin when you get it all back together.
the spring is not very strong and if you can get both hands under there, then just wedge the spring up and then try to force the can bar back in. its not easy but keep trying as pulling the trans. out is alot harder.
Jan 07, 2009 | Whirlpool GSC9455 Top Load Washer
Saw is running, but chain is not moving
If you rev the engine and the chain does not spin, either the chain is jammed, or is adjusted to tightly on the bar, or the centrifugal clutch is malfunctioning. With the engine off and leather gloves on, see if the chain will move on the bar, you should be able to move the chain 4 or 5 inches. If you can spin it, the clutch is probably bad. If its stuck, take the housing off over the clutch and make sure the chain is seated on the sprocket and not jammed to the side. Inspect the chain on the bar, there should some slight play in the chain tension. Look for any links that dont flex. This happens to be cause I overtighten the chain to the bar.
Dec 22, 2008 | Homelite Garden
Kenmore Washer Spin Issue - Need help troubleshooting
Check the coils on the wig-gag. Its a couple of bars that engage the spin drive or the wash drive. If you look at the machine when its running you will see it moving back and forth, hence the name. If the coil engages the spin cam, but it still will not spin then the tranny is your next culprit.
Jan 04, 2008 | Washing Machines
Whirlpool GSC9455 Top Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
