Question about Goodman GMS90703BXA Heater
Goodman furnace won't ignite. No glow from ignitor.
Can I assume that the ignitor is bad? the little red light does nothing but shine on.
  • Goodman Master
  • 3,183 Answers
Yes if the ignitor has a very small crack on it it will not work replace it and see if it works but do not touch the end that glows when you put it in as the grease from your finger s will stop it working
Posted on Jan 08, 2009
Sometimes, when we start the carmera and want to take a photo and press the button to take one, a small red light starts to shine. we didn't configure anything on the settings. this is really anoying
Sounds like a feature that comes on when using flash. The light comes on so in low light you can see and focus on what you are trying to photograph. Then we shutter button is depressed all the way the flash goes and picture is taken. Try turning off flash function.
Apr 23, 2014 | FUJIFILM Instax 210 Film Camera
None of the lights on my Ford 4600 County, 1977 are working. The only electrical things that works is the starter and the fan. When i turn the light switch to full i see the little blue light are shining....
soundz like a rusted ground wire somewhere...u can usually get wiring diagrams for a lotta vehicles through PDF files on the net...I think the blue lite which I assume is ur high beams is on, it almost certainly soundz like a bad ground or bad switch...
Dec 18, 2013 | Cars & Trucks
I have a 10 year old honeywell furnace controlled by a SV9541 smart valve. We finally had to switch to heat but no heat. Tried restarting - system does nothing. Checked to make sure the gas line is open...
Sounds like the Ignitor unplug the ignitor check for continuity if no continuity replace Ignitor or you can usually see the crackon the Ignitor with white residue.
Sep 18, 2013 | Honeywell Programmable Thermostat Heater
Furnace starts up blower starts..nothing ignites...then shuts down. repeats and doesnt stop...sanded igniter stick and nothing happend. flashes red once.
Do you see the actual ignitor glow? You must be saying that you sanded the sensor. The ignitor, after the little inducer fan comes on will begin to glow a bright orange until the burner lights. If the ignitor is broken, you will NOT see a glow, and you may smell a faint smell of gas.
Apr 14, 2011 | Goodman GMS90703BXA Heater
Controls work fine , element glows red, but stove dorsnt light, huh.
Ok, I'm assuming the element is the ignitor right? The trick here is the ignitor, if it's a glow type. The ignitor must decrease it's resistance enough to allow the gas valve to receive it's calibrated min current to open. If the ignitor is bad it can glow just fine but if the intensity is not sufficient, the resistance will not be decreased enough to trigger the gas valve. Sorry to get complicated. I would replace the ignitor first and go from there. Hope this helps.
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
Turn on tv, no picture no sound, shined light into screen,nothing
Check your connections and scart leads, take them out and put them in again. It may be a loose lead or maybe a faulty lead, swop them over to see.
Apr 28, 2010 | Olevia LT32HVM 32 in. LCD Television
I have a Magic Chef stove Model # 31001SAW. It is made by Maytag.I need to replace the ignitor switch in the oven. The light(flame) comes on but the gas does not ignite. I am assuming that the ignitor...
if the ignitor is not a brite red than it is not putting out the 3.5 amp's neaded to open can check the valve with a continueaty meter.remove the two wire's from the valve and check valve with meter,if valve check's good than ignitor is bad.
Nov 18, 2009 | Ovens
Where can I light the pilot
You're dryer has an ignitor not a pilot. To check, either pull the lower front panel or pop out the key hole. Start dryer and watch if the ignitor comes on it should shine brightly almost white. If it does'nt light at all(should at least turn red). there could be no voltage to the ignitor.
Jun 19, 2009 | Whirlpool Dryers
Oven will not light
One of the Ignitor/orifice assy.,electrode is bad expecially the one your wife have to light.The circuitry is ok,but change that bad ignitor/orifice assy electrode.
Part number is Item # 833121: check it out @
Jul 04, 2008 | Frigidaire FGB24S5A Gas Single Oven
Maytag Range MGR6875ADB will not light and no clicking sound
Sounds like your electronic ignitor is not getting the supplied voltage,it could be the contol box or a bad ignitor.The gas valve will not open when this is the case.I assume you know how to use a meter.Check that the breaker is not tripped,check line voltage to the ignitor.If supplied voltage is there when the unit is turned on, the ignitor is bad.That's why no clicking!!
Nov 21, 2007 | Ovens
Goodman GMS90703BXA Heater Logo
229 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
