Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Use hdmi out on 2408 display
Can I connect stereo cable to hdmi out on dell 2408 display and get aux speakers (hk candleticks) to work?
  • 88 Answers
No, won't work as teh monitor does not have sound capabilities. However, this will work if you have some sound input into the monitor, like if you use the HDMI (which includes sound) to send signals to the monitor, instead of the VGA / DVI connector. (All sound output on a system is from the sound card on the system only, monitor sound options are usually just an extension of the same)
Posted on Jan 12, 2009
Not getting any sound out of speakers help please :(
You need to set the device on the aux mode. Connect the cable at aux. Sign at the back of the device
good luck
May 07, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Service center chennai
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable? Have you checked the subwoofer for any faulty wiring although i would may be discard that idea as if it was faulty it would lose sound altogether. But still may be have a look to cross that off your list you never know. But to me i think you have a faulty channel or Aux connection/speaker connection on your amplifier/stereo.
Jan 06, 2014 | Jamo Audio Players & Recorders
Volume problem--laptop to tv
I'm confused, are you trying to use a VGA cable for both video and audio? VGA cables don't have sound built into them, nor do DVI. If you had an HDMI plug on your laptop it would be best to go with that since HDMI contains video and audio.
You could just use an Aux cable from laptop to TV. Pretty much it would be a aux to analog type. It's like a speaker plugin, that side is for your computer. Then the other side coming out would be an analog red/white or left/right cable.
Another one, if your TV supports pure aux cable (it's a 3.5MM jack that speakers plug into) Like, my tv has a built in aux port for audio for my computer. So I just use pretty much a standard cable to cable setup.
Feb 24, 2013 | Toshiba Satellite Computers & Internet
I have an HK AVR 355 system, that worked just fine. Yesterday I tried to hook up a new TV, and ended up taking a few cable out since they were not imoportaint any more and only used HDMI cable. Now when I...
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Aug 17, 2011 | Harman Kardon Audio Players & Recorders
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
No sound on my dell optiplex 330
Unless you have headphones, you need speakers, preferrably amplified speakers.
Another way the address the issue is to use a cable to connect your computer to your home stereo if it has an auxilery input (aux/cd/tape input) then all you need is a cable with two male RCA plugs on one end and an 1/8 inch stereo plug on the other end.
The 1/8th inch plug goes into your computers' sound "out" and the rca's go into the aux/cd/dvd "IN" on the stereo.
this cable can be purchased for under 10 dollars at walmart, though amplied speakers wont be much more expensive.
Hope this helps you decide which direction to go..
Regards..
Apr 04, 2009 | Dell OptiPlex 330 Desktop Intel Celeron...
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
185 people viewed this question
Alun Cox
