Question about Kitchen Appliances - Others
Lennox Conservator G8E Short Cycling
As the problem states, I have a Lennox Conservator G8E natural gas model that recently started short cycling. Furnace fires up, heats up the heat exchanger, fan starts, runs for about 15-20 seconds, and shuts down. The thermostat isn't satisfied and it waits about 60 seconds and does it all over again until the therm is satisfied. So I was wondering if anyone had wiring diagrams that could point me in the right direction for checking the limit switches on the Lennox Conservator G8E. Thanks for your time.
  • carl carpenter
    carl carpenter May 11, 2010
    check your ground to the unit also you may want to try to clean the metal rod that is located by the burners this is your flame sensor
Change the filter.
Posted on May 22, 2010
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
Why is my heating system short cycling?
What is your Temperature Rise across the furnace? Match this with the name plate. This tells you a lot. Is the t-rise higher or lower? If its higher, you could have restricted airflow or exhaust issues. If its lower, could be gas pressure or duct work problems, pulling in colder air somewhere. More info is needed to help. I am assuming the furnace is operating continuously when you say it will not heat over 66 degrees?
Feb 16, 2015 | Heating & Cooling
Our Lennox Conservator G8E furnace goes through several ON-OFF cycles (we counted up to 10 clicks) before it stabilizes and stays ON. Once it's ON it works fine. - Any suggestions?
If its a gas furnace it could be the heat sensor on the pilot flame unit. When the sensor is failing it stops telling the control that the pilot is lit properly and the furnace goes thru another start up sequence.
You can try to scrape any flash and dirt off of the heat sensor rod to clean it or remove it and clean or replace the sensor or the pilot assembly. There are plenty or furnace parts on Amazon. The next most likely thing is the relay board is ready to fail that part is ~$80 but you need to get the part number right and be experienced with wiring.
WARNING-DANGER B4 you do anything to your furnace Turn Off The POWER first! If there is no plug or switch near by, shut of the circuit breaker! If you don't know what any of this means then you are likely not a good choice to mess with this device
Be Safe :)
Nov 09, 2013 | Kitchen Appliances - Others
I have a H200 NG Electronic it will lite but will only run for 5 seconds
"Short Cycling" is generally and indication of a flow problem. Locate the pressure switch, disconnect the two leads, jump them together and try again. If the heater stays on you either have a low pressure situation or the switch is bad. Do not continue to use the heater without correcting the problem.
Apr 22, 2010 | Hayward H Series Natural Gas Electronic...
My unit is cycling on and off every 2 minutes or so.
This can be due to a faulty thermo sensor or if the unit is fitted with a pressure safety switch, it could be short of refrigerant.
Mar 09, 2009 | Carrier 38BRC036 Air Conditioner
Gas furnace short cycling. checked by experts no solution
This is tough one. If you have an older mercury type thermostat, behind the cover theirs a small copper pointer that points to some numbers. This is your heat anticapator. This setting has to match your milliamp draw of all the controls on your furnace. If set to low it over heats and fools the thermostat into thinking its satisfied. Move the point to a higher setting in little increments. Hope this works for you. Can't help with the vibration without hearing it.
Mar 03, 2009 | DCS Large Appliances Built-In Ovens...
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Kitchen Appliances - Others Logo
755 people viewed this question
Top Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
