Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
Vertical color bands take the place of the picture.
If I turn the TV off for 15 mins. or more, the picture will come back for 15, 30, 60, 120 mins, 180 mins., then back to the vertical bands of rolling colors.
I sent my question to the "solve your problem for free" on this website, so I was expecting some "free" advice. My finances are such that I can only ask for free advice. I did see someone who had a similar-sounding problem, and there was a mention of two possible main boards that would fix the problem. I was hoping to know which board would most likely fix my problem, since the TV is less than two years old. If I take it to a TV repair person, I want to have a fairly good idea how to fix it, and what would be the approximate cost, so I do not get ripped off.
Posted on Jan 08, 2009
I have a Sony KDLW3000, the picture has colored vertical lines on the whole screen,
The Tcon board is usually at fault with that symptom. You can get a replacement Tcon from www.tvrepairworld.com
Apr 01, 2012 | Sony KDL Televison & Video
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
My trutech tv goes off about 15 to 20 mins after i turn it on, why is that?
Check the sleep mode might be on?Sleep mode on like 30,60,120 times all up,run out will go off.Will automatic,tv will shup off.
Feb 01, 2011 | TruTech PLV16320 Television
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Color off
You need to have the pins of your convergence IC's checked for ring cracking. That cooling-off period is probably just enough to bring the crack(s) back into contact with each other and as they heat up they separate. It doesn't sound like a IC or component failure, at least not yet. But if it's ring cracked that arcing that happens is placing stress on the Ic's and they could eventually fail... Good Luck Bill
May 24, 2007 | Samsung HCL552W 55" Rear Projection...
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
308 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
