Question about Pioneer VSX-D710S Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off.
  • 8 more comments
  • Anonymous Nov 13, 2007
    I have exact same problem with my pioneer receiver (VSX-D810S) too.
    We seldom use it but one year ago it started to power off soon after I turned it on.
  • water23 Jan 10, 2008
    I have two friends with the Pioneer VSX-D810S receiver that have developed the same problem. I have not found a fix in my research.
  • Anonymous May 14, 2008
    I have this same problem what do you do? Is the receiver shot?
  • Anonymous May 17, 2008
    me too...same problem....only mine lasted 5 years before it startd
  • ltsgoynks Jun 07, 2008
    Same problem, POWEROFF, after 4 secs.
  • jpaqman11 Sep 27, 2008
    Every time I turn on the reciever it will turn on then it says poweroff. What can I do to fix this?
  • Ron Ray Oct 15, 2008
    I am also having this problem with a VSXD710S. All I have found so far is there may be a speaker wire strand shorted to the oposite terminal. If so unplug the receiver and remove. (You have to plug and unplug to reset the fault latch). I found this on the Pioneer web site. This was not my fix though, I'm still looking.
    Same problem, Power off blinks then unit powers down. Pioneers web site says to check for a loose strand of speaker wire on the terminals. You have to cycle power (unplug) to clear the fault latch. Unfortunately this didn't do it for me.
  • eytheone Mar 31, 2009
    mine sat for a year then started this problem
  • Michael Houda Jun 04, 2019
    the power out put may be shorted and going into protect a service manual is available at to download freehttps://www.manualslib.com/manual/700504...
    Problem Solver:
  • 10 Answers
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
Posted on Aug 19, 2008
  • dustinolneyy
    dustinolneyy Aug 25, 2012
    so how did you fix it?
    New Friend:
I have unplugged all speaker wires, rca video/audio cables, and still continue to power down.......Lost!!!!!!!
Posted on May 15, 2012
I have the same problem, the unit powers powers off after a couple of seconds. What needs to be done to resolve the error? Looks like this is a common issue with the receiver.
Posted on Nov 16, 2007
SOURCE:
My friend kept turning it up and i kept turning it back down then it just said poweroff
Sounds like your "friend" has cooked something. It could be one of your speakers (do they all sound ok for the 5 seconds it runs?), or it could be the receiver....
I would try disconnecting all the speakers and see if it stays on. If so, it may be one of the speakers. Connect them one at a time, and see if you can tell.
Nov 10, 2015 | Pioneer VSX-D308 Receiver
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
POWER OFF/ SHUTDOWN
Hi,,,thanks for your good response...Understnding a 7.i surround system through chat is difficult...that ws why i couldnt get it right...if i was there at your place i would have solve that it in seconds...anyway you got it done by yourself thats what we wanted...thanks again
May 25, 2008 | Denon AVR-1905 Receiver
Pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: [email protected]
Nov 20, 2007 | Pioneer VSX-456 Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
"POWEROFF" display comes up randomly
there may be broken soldering points in the receiver take it to a workshop or open it your self and check it on the power source
Jul 02, 2007 | Pioneer VSX-D509S Receiver
Pioneer VSX-D710S Receiver Logo
2,720 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
